Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 09-14-2010 | 11:30 AM
  #4006
Originally Posted by houston
cranks overtimed , thats why
there were a few of those that had some cranks that were opened up too far in the duration (trailing edge) resulting in loss of top end
fix; new crank
So what crank can i put in it to make it a screamer? Thanks speedy
Speedyrob is offline
Old 09-14-2010 | 11:32 AM
  #4007
Hey Monty,
So I have a Plus21-4C that the piston rod retaining ring decided to break and take out the piston and sleeve... Any chance you have the part number for the piston and sleeve set and where to buy?
Stirex is offline
Old 09-14-2010 | 12:47 PM
  #4008
houston's Avatar
Tech Prophet
Originally Posted by Stirex
Hey Monty,
I have 3 or 4 new sets , pm me
houston is offline
Old 09-14-2010 | 10:38 PM
  #4009
KWT-NITRO's Avatar
Hey Monty,
i asked earlier but your skipped my post as always
do you have a P5XLT cooling head in stock??
cheers
Ali
KWT-NITRO is offline
Old 09-15-2010 | 06:38 AM
  #4010
houston's Avatar
Tech Prophet
Originally Posted by KWT-NITRO
Hey Monty,
cheers
Ali
I have some new p5xs heads which are the same size but no p5xl
houston is offline
Old 09-16-2010 | 01:07 PM
  #4011
Dave De Voe's Avatar
Thumbs up promps
digin the new motors Monty.
Dave De Voe is offline
Old 09-16-2010 | 01:11 PM
  #4012
KWT-NITRO's Avatar
No thanks bro, a friend needs a replacment for his P5XLT, i told him today about the P5xs and he doesnt want it.
thanks again,
are my babies screaming yet ??
cheers
Ali
Old 09-17-2010 | 11:49 AM
  #4013
Trevor Williams's Avatar
Ali,
yes they are, please stop being mean to them and feed them!
Trevor Williams is offline
Old 09-17-2010 | 03:28 PM
  #4014
KWT-NITRO's Avatar
Originally Posted by Trevor Williams
Ali,
dont worry bro, ill take good care of them and they will drink lots and lots of 30% Byron i just wanna hear them scream my name
Old 09-17-2010 | 03:59 PM
  #4015
houston's Avatar
Tech Prophet
in the cars ready for fuel
houston is offline
Old 09-17-2010 | 04:02 PM
  #4016
Do-Over's Avatar
Random question... Maybe it don't belong here but I'm asking it here anyway. My friend just got a Toro Nero team yesterday. I showed up to see the unboxing. Yeah, we're that into it after only a few months. We found in the package where the venturi's are 2 or 3 little shims that look like... uh... clutch shims I guess but I know that can't be it. In the directions it says something about your putting them in the motor I can't remember now. I'm dyslexic so I'm not good with written stuff anyway. I would assume you guys know what they are and might be able to tell me what they're for. Not for my friend, I hope he has it figured out, I just want to know. Not head shims, little washer looking things.
Thanks,
Rich
Do-Over is offline
Old 09-17-2010 | 05:05 PM
  #4017
houston's Avatar
Tech Prophet
Thanks,
Rich
they are high speed needle gaskets
you are suppose to replace the gaskets every time you move the fuel inlet banjo on the high speed needle assembly but i recommend it not needing to be done
only if they leak
i havent had one leak in 4 years
houston is offline
Old 09-17-2010 | 07:30 PM
  #4018
cordarrow's Avatar
I like to put Lucky 7 on a toothpick and run it around both gaskets and the base...whether I move it or not.
cordarrow is offline
Old 09-17-2010 | 10:12 PM
  #4019
Do-Over's Avatar
Do-Over is offline
Old 09-18-2010 | 10:01 AM
  #4020
BLKNOTCH's Avatar
Hi Monty so as I was posting earlier I have gone ahead and ordered my new front bearing and con rod along with new wrist pin clips, do you have any tips for replacing the con rod? I don't see how I will be removing the wrist pin? I do see slight grooves in the piston which look to be where I will pry out the wrist pin clip but can you confirm for me.
Sean
BLKNOTCH is offline
