Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 07-11-2011 | 05:13 PM
  #5506
Default idle??
My hes p5 will not idle once it warms up and I am getting When I 1st fire it up it will idle for ever but after a tank it's a no go. Engine is running well apart from this around 9 mins a tank @ 260 ish on a exergen gun. I have done the usual air leak checks and nothing only thing I have not changed is the mugen fuel tank. Any idea's would be welcomed and appreciated also base needles as well. I've read through the tuning section and watched the novarossi vid and I'm stuck
Thanks again.
jet flyer is offline
Old 07-11-2011 | 06:20 PM
  #5507
any word on an updated spec p5?
C.Harper is offline
Old 07-11-2011 | 06:36 PM
  #5508
kgombe's Avatar
Originally Posted by nick64merc
Monty I have a question for you on a FMS. I am running it in a MBX6 Buggy. Right now I am running the Ninja FLS Pipe on it, but I was wondering what you think would be the best setup for it. I have an 086, 9901, or the Ninja pipe. I race out at Rev and ARC quite a bit here in Socal. Nice open tracks.
Nick
i would run the 9901 long header (41020) i run the 2084 with the 41021 header in a D* and i luv it
kgombe is offline
Old 07-11-2011 | 08:08 PM
  #5509
houston's Avatar
Thanks again.
sounds like a low compression situation
you can try to drop head shimming to .70mm or send it in to raya racing for a resize
how much of what fuel ?
is you r filter system up to snuff?
has it sucked dirt ?
have you always ran it hot?
houston is offline
Old 07-11-2011 | 08:12 PM
  #5510
houston's Avatar
you mean my version of a p5?
i am pretty partial to the fusion x line lately, ran the x3 in my buggy last weekend , lil smaller track and it was DIALED!!!!
x7 and 2096ss in truck runtime was ridiculous!!!!
houston is offline
Old 07-11-2011 | 08:14 PM
  #5511
houston's Avatar
+1 out of the pipes mentioned
houston is offline
Old 07-11-2011 | 08:16 PM
  #5512
houston's Avatar
Originally Posted by Dave De Voe
Monty I just pained a new body for my AE and I'm out of you HES stickers PLEASE HELP!!!!Could you send me some???These are very vital(in yellow if you got)...
you going to medford race?
i got a few boxes that will be ging down so i can throw a few in there
houston is offline
Old 07-11-2011 | 08:27 PM
  #5513
freefallmarine's Avatar
I want sticker's!
freefallmarine is offline
Old 07-11-2011 | 08:33 PM
  #5514
houston's Avatar
Originally Posted by freefallmarine
I want sticker's!
ya ya , i still gotta send ya that crank so i can put some in there
everybody bug me about your orders so i can keep up with it all thanks guys
houston is offline
Old 07-11-2011 | 08:42 PM
  #5515
Thanks Monty I'll try a re shim, Byrons 30% only. It usually runs a bit cooler than that but it's been 100 degrees+ here. I swap my filters after each run but will have a good look inside when I pull it apart.
Old 07-11-2011 | 10:24 PM
  #5516
houston's Avatar
Any interest in these ?
I had a few light werks clutch setups milled out for testing and they worked like a champ!
Lmk if you guys are interested and I can get more done
I made these for truggy or high traction buggy
Attached Thumbnails Houstons Engine Service H.E.S.-img_20110711_221754.jpg   Houstons Engine Service H.E.S.-img_20110711_221712.jpg
houston is offline
Old 07-12-2011 | 07:53 AM
  #5517
Monty,
I pulled the shim and cant not find any evidence of dirt but I want to reset the needles to base and start again so what would you recommend? This is one of your full mod p5's.
Thank you.
Old 07-12-2011 | 10:07 AM
  #5518
totld1's Avatar
I am interested in one for my truggy
totld1 is offline
Old 07-12-2011 | 01:40 PM
  #5519
houston's Avatar
Consider on yours bob
houston is offline
Old 07-12-2011 | 01:44 PM
  #5520
houston's Avatar
Monty,
Thank you.
About 4.25-4.5 turns out from bottomed out on lsn and 3.25-3.5 on hsn , idle about .7mm
houston is offline
