Team Magic E4 Thread
#3436
I have tried different setup with the car on different track surface but I have always gone back to the stock setup with vey little adjustment and the car is dialed. I basically use the same setup and just play with the shock oil and camber changes this all depends on the level of grip that the track has.
#3437
Hello
Here you can find some interesting pictures:
http://www.overrc.com/techniques/reg...giclionel.html
E4RS 09: TQ at the last Swiss Championship in Lostallo - Stock Category (13.5)
#3439
#3440
They're carbon body post stiffeners for the E4D
http://www.rcshopping.com/profra.jsp...2137&proclass=
#3441
State titles vid
http://www.youtube.com/watch?v=Z4urM6Ht1v4
Our E4 has a Lime/yellow flamed TM shell.
#3442
I have an DE E4. I'm not the original owner and don't have all of the paperwork. Can someone PM the stock setup?
#3443
State titles vid
The E4 is underpowered for the tight competition in the mod class, our Losi ESC and 4.5 Motor combo served us well and it's very much a situation that the E4 wants more power and Im not sure it won't struggle.
For me it's silly grub screw holding the C hub pins that really lets the default car down. Ive seen some nice gear at wolf's but for now it's a matter of finding more power and seeing what the transmission makes of it.
Fortunately we managed to find a front belt tensioner before this event and it saved us from a sure set of belt failures.
Ultimately the E4 gobbled up the Losi 4.5 and while its by no means a powerhouse, it's been very reliable. Anyone else run mod?
Purple on the front, pink on the rear and stock sway.. had a good event... http://www.youtube.com/therealblis?g.../0/G6QmNXZor2A
#3444
I'm having some issues with the front uprights and was wondering if someone could enlighten me. It seems that the top hole in the front upright keeps enlarging itself. The first set of uprights I had were the DE black aluminum. Next I put on a set of 6 degree plastic uprights. The DE had an enlarged hole for a bearing while the plastic ones did not. Both sets had enlarged holes after only a few runs. This creates a fair amount of slop. I see that Wolf Hobbies selling a silver aluminum set of uprights but those are $60 a set, that's expensive. Any help / suggestions in this matter would be great.
#3445
Just get the stock 3 degree aluminum or the wolf hobbies aluminum C-hub It cost a lot but this will solve your problem and you will never purchase another C-hub they are pretty strong. I do recommend wolf hobbies they are beffier and truer.
#3447
#3450
Those are i believe the K-factory 3 degrees C-hubs.
You need to use these http://www.wolfhobbies.com/Wolf_Hobb..._Degree_2.html
They are almost half the price and with the ballbearings in them last a life time without problems.
regards Roy
regards Roy
