Old 09-06-2010, 06:51 PM   #3436
Jochim_18's Avatar
I have tried different setup with the car on different track surface but I have always gone back to the stock setup with vey little adjustment and the car is dialed. I basically use the same setup and just play with the shock oil and camber changes this all depends on the level of grip that the track has.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 09-15-2010, 10:35 AM   #3437
Hello
Here you can find some interesting pictures:
http://www.overrc.com/techniques/reg...giclionel.html
E4RS 09: TQ at the last Swiss Championship in Lostallo - Stock Category (13.5)
RC Infos is offline   Reply With Quote
Old 09-15-2010, 10:39 PM   #3438
Questions??
Hello
Anyone know what these K factory parts are for K2137 and K2138.
DKM-Kiwi is offline   Reply With Quote
Old 09-15-2010, 10:59 PM   #3439
Pro10noob's Avatar
It looks like a brace but don't know if it is for the E4 or not.
Drop K-Factory a mail and you know
cheers Roy
Originally Posted by DKM-Kiwi View Post
Hello
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 09-16-2010, 10:29 AM   #3440
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Hello
They're carbon body post stiffeners for the E4D
http://www.rcshopping.com/profra.jsp...2137&proclass=
YR4Dude is offline   Reply With Quote
Old 09-25-2010, 03:22 PM   #3441
blis's Avatar
State titles vid
http://www.youtube.com/watch?v=Z4urM6Ht1v4
Our E4 has a Lime/yellow flamed TM shell.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 09-26-2010, 10:29 AM   #3442
phisher's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Jochim_18 View Post
This car like a really balance setup just make sure your front and rear seup is very close to make this car handle really good. The stock setup on the original E4 is a very good starting point and just make adjustment from their for different track surface.
I have an DE E4. I'm not the original owner and don't have all of the paperwork. Can someone PM the stock setup?
www.MichiganRC.net
phisher is offline   Reply With Quote
Old 09-28-2010, 03:11 AM   #3443
blis's Avatar
Default E4 looked great on track
Originally Posted by blis View Post
State titles vid
Part II
The E4 is underpowered for the tight competition in the mod class, our Losi ESC and 4.5 Motor combo served us well and it's very much a situation that the E4 wants more power and Im not sure it won't struggle.
For me it's silly grub screw holding the C hub pins that really lets the default car down. Ive seen some nice gear at wolf's but for now it's a matter of finding more power and seeing what the transmission makes of it.
Fortunately we managed to find a front belt tensioner before this event and it saved us from a sure set of belt failures.
Ultimately the E4 gobbled up the Losi 4.5 and while its by no means a powerhouse, it's been very reliable. Anyone else run mod?
Purple on the front, pink on the rear and stock sway.. had a good event... http://www.youtube.com/therealblis?g.../0/G6QmNXZor2A
Old 10-13-2010, 07:32 AM   #3444
phisher's Avatar
I'm having some issues with the front uprights and was wondering if someone could enlighten me. It seems that the top hole in the front upright keeps enlarging itself. The first set of uprights I had were the DE black aluminum. Next I put on a set of 6 degree plastic uprights. The DE had an enlarged hole for a bearing while the plastic ones did not. Both sets had enlarged holes after only a few runs. This creates a fair amount of slop. I see that Wolf Hobbies selling a silver aluminum set of uprights but those are $60 a set, that's expensive. Any help / suggestions in this matter would be great.
www.MichiganRC.net
Old 10-13-2010, 08:14 AM   #3445
Jochim_18's Avatar
Just get the stock 3 degree aluminum or the wolf hobbies aluminum C-hub It cost a lot but this will solve your problem and you will never purchase another C-hub they are pretty strong. I do recommend wolf hobbies they are beffier and truer.
Old 10-13-2010, 08:30 AM   #3446
Jochim_18's Avatar
What everyone prefers to use dual or single steering bell crank?
Old 10-13-2010, 09:22 AM   #3447
phisher's Avatar
You're referring to these?
http://www.wolfhobbies.com/E4_Parts-..._3_degree.html
www.MichiganRC.net
Old 10-13-2010, 09:57 AM   #3448
Jochim_18's Avatar
I would get the wolf hobbies aluminum c-hubs they are cheaper.
Old 10-13-2010, 10:04 AM   #3449
Jochim_18's Avatar
Old 10-13-2010, 10:37 AM   #3450
Pro10noob's Avatar
Those are i believe the K-factory 3 degrees C-hubs.
You need to use these http://www.wolfhobbies.com/Wolf_Hobb..._Degree_2.html
They are almost half the price and with the ballbearings in them last a life time without problems.
regards Roy
Originally Posted by phisher View Post
l===/o\===l
team magic m1b pitdog Nitro Off-Road 447 04-30-2013 09:17 AM
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
Team Magic G4 J_Longbrake R/C Items: For Sale/Trade 0 10-07-2004 07:56 PM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
