Old 10-13-2010, 10:39 AM   #3451
phisher's Avatar
Trader Rating: 14 (100%+)
Alright. I want to say that those were the ones that came on my DE E4, the same ones that enlarger the first time but, maybe not. I will give them a try.
www.MichiganRC.net
phisher is offline   Reply With Quote
Old 10-13-2010, 10:46 AM   #3452
Pro10noob's Avatar
Did you have ballbearing in the c-hubs or where there brass bearings in them?.
I find it weird that you had enlarged holes where there should be a ball bearing.
I have both the Wolf Hobbies hubs and the K-Factory but didn't have any issiues with both of them.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-13-2010, 10:52 AM   #3453
Jochim_18's Avatar
Those are the stock C-hubs but they only included on the original E4 the K-factory ones are black anodized.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 10-13-2010, 11:07 AM   #3454
Pro10noob's Avatar
Erhmmmmmm the 3 degrees K-factory are silver colored and the 6 degrees K-factory are black anodized.
K-factory made the stock c-hubs for the original E4 i believe
Check pic these c-hubs are 3 degrees and from K-factory
Regards Roy
http://img121.imageshack.us/f/e4fs5.jpg/
l===/o\===l
Old 10-13-2010, 11:14 AM   #3455
phisher's Avatar
The uprights that came on my DE E4 (I am not the original owner so I'm not 100% sure) were black aluminum and were 3 degrees. They did come with ball bearings in them (not bushings) and the right side was enlarged. I had thought it might have been wrecked before I got it but, when the same thing happened with the plastic uprights, it got me thinking.
www.MichiganRC.net
Old 10-13-2010, 11:19 AM   #3456
Pro10noob's Avatar
The plastic c-hubs do tend to wear a bit yeah but the alu c-hubs i have i never got any problems with.
Sold one of my E4FS with the Wolf hobbies 3 degrees c-hubs on them and the guy who is driving it is still happy with them.
No problems with wear or anything.
regards Roy
l===/o\===l
Old 10-13-2010, 03:05 PM   #3457
Jochim_18's Avatar
I had mine for 2 years it is still slap free.
What's is everyone using on their E4 dual or single steering bellcrank?
Old 10-13-2010, 04:37 PM   #3458
Pro10noob's Avatar
I am using single because of less parts that can come loose,less slop and direct responce.
regards Roy
l===/o\===l
Old 10-15-2010, 08:00 PM   #3459
bjames's Avatar
Trader Rating: 24 (100%+)
Hey, I'm a long time losi r driver that recently decided to try something new so I got a E4 DE edition. It was used and came with no tuning parts (springs, swaybars, etc.) It looks like the rear springs are associated green springs. Anyways, what all should I get for this car for tuning, as far as springs, caster blocks, swaybars... Also, it had no manual, is there roll center adjustment as far as moving the a arms up or down? Thanks for any help. BTW i run on asphault tracks, indoors and out. Any advice on what to order would be great.
-Brian James-
bjames is offline   Reply With Quote
Old 10-15-2010, 08:25 PM   #3460
Jochim_18's Avatar
You can adjust the roll center, anti-dive, anti-squat by shimming the suspension blocks and camber links. Get the K-factory spring set, I recommend getting the PU belts, and use the rear belt on the front they are thicker, change the middle and side pulleys to the plactics ones it will save you a headache the aluminums ones tend to strip the belt pretty quickly especially if you are running mod.
Since you got the DE E4 you pretty much got all the hop-ups you need. But I recommend replacing the bearing either use metal shield bearing if you wanna go cheap or ceramic bearing. This will free up the car more.
Old 10-16-2010, 07:21 AM   #3461
bjames's Avatar
Cool, thanks for your help. I cant wait to raise some eyebrows at the local track...All they run is TOP and Xray.
-Brian James-
Old 10-16-2010, 08:08 AM   #3462
Jochim_18's Avatar
contact yodog here in the forum you will need his battery tray to fit those big lipo packs without raising the top deck.
Old 10-18-2010, 03:49 PM   #3463
YoDog's Avatar
Trader Rating: 26 (100%+)
Thanks for the shout Kimo...
I'll be making more battery trays this week so If anyone wants in, PM me.
$55 shipped in the Continental US.
Outside will adjust for the difference.
For those of you who bought a tray from me, could you please provide an update on how they are working out for you. Any suggestions or feedback is always welcome.
Suggest a part?
YoDog is offline   Reply With Quote
Old 10-18-2010, 06:15 PM   #3464
Jochim_18's Avatar
1. Top deck for low traction track.
2. Aluminum dual steering bell crank.
3. Lipo chassis with no cut outs I'm finding the RS chassis is inconsistent with un-even flex. Probably that's why the original E4 chassis works better on asphalt the car handling is more predictable.
Are you racing this weekend Rick?
Old 10-18-2010, 06:23 PM   #3465
Jochim_18's Avatar
The car handles really well and very easy to drive. I have run pretty much all the top major brand on the market but this car is not sensitive to different track surface. You can pretty much run the same setup with some small changes and your pretty much spot on.
team magic m1b pitdog Nitro Off-Road 447 04-30-2013 09:17 AM
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
Team Magic G4 J_Longbrake R/C Items: For Sale/Trade 0 10-07-2004 07:56 PM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
