Team Associated RC8Be Thread >
Old 08-12-2010 | 09:45 AM
  #166
longbill76's Avatar
Hey Guys,
Thanks for posting great feedback on my mount, I truly appreciate all your support
As you may know my mounts are sold out once again, I am currently making more and should be finished early September or maybe sooner.. please check my thread for updates..
longbill76 is offline
Old 08-12-2010 | 10:47 AM
  #167
b_recliner's Avatar
Make a ton of those things Brandon. They are marvels of design and I guarantee they will sell for the RC8 model. I know of many people just in my area who are interested.
b_recliner is offline
Old 08-12-2010 | 11:02 AM
  #168
Originally Posted by longbill76
Hey Guys,
Yup, I need one also. I sent you two e-mails but never received a reply. You must make a nice product to have all the folks here wanting one.
MulliganAl is offline
Old 08-12-2010 | 05:04 PM
  #169
longbill76's Avatar
I will make a larger amount on the next batch, the last batch I made 100 RC8 mounts I had no idea it would sell so quickly..
MulliganAl I never received your emails, please email me again and I will have you on a waiting list. this goes for anyone else who is interested..
Email me and I will have you on a reserve list..
Thank You!
Old 08-14-2010 | 01:35 AM
  #170
millerdui's Avatar
Default elite rc mount lesson learned
my asc pinions will not work with my Elite rc mount. The set screw side of the pinion is too long for me to get the proper mesh with the spur (front to back) I will have to use a losi, novak etc type pinion. Just a heads up for new buyers/installers
millerdui is offline
Old 08-14-2010 | 09:56 AM
  #171
Default ESC & Battery
Well I'm almost finished building my very first 1/8 buggy but I was wondering which battery connectors most of you use with the Mamba 2200 and what size connectors are best?
I was looking at some of the Dean connectors but can't figure out which are best for the 2200.
Also, do you guys wrap your motor to ESC cables?
Old 08-14-2010 | 10:53 AM
  #172
+ 1 - I REALLY want one!
Just read your reply Brandon - make 101!
Smokeyr67 is offline
Old 08-14-2010 | 06:01 PM
  #173
millerdui's Avatar
got my 6s system put in today. ran a few laps here at the house to break in the batteries. the 9oz weight lose is very noticable. thing's got more steering than i know what to do with, pushing is gone. It will almost pivot on the front-end without braking.
What is the lightest weight allowed to run at most races on 1/8 ele.
i should be around 6lb 11oz +/-.
Anyone have some base set-ups for running an RX8,1400kv motor, and 6s 2650mah. I am geared 18/50 until my 17tooth pinion comes in.
Thanks guys
Old 08-14-2010 | 07:51 PM
  #174
longbill76's Avatar
Please use Hotbodies pinions they have the shortest shank, or my 2nd choice would be RobinsonRacing
Old 08-14-2010 | 08:13 PM
  #175
What is the battery tray width?
MMor101 is offline
Old 08-14-2010 | 10:37 PM
  #176
BLbound's Avatar
Thanks guys
How long of a main event can you last with a 2650 mah battery? Would that last for a 10 minute main?
BLbound is offline
Old 08-15-2010 | 06:45 AM
  #177
millerdui's Avatar
should be able to make 12 minutes. My buddy is making 12 minutes on 2200mah battery with a different motor setup. I should be ready to get some runtime ideas today.
Old 08-16-2010 | 12:06 PM
  #178
jboquire's Avatar
Hey guys,
I started putting my RC8Be this week and noticed that the manual does not call for any type of lubrication between the crown and pinion gears, is this correct or you guys use grease?.
regards, jb
jboquire is offline
Old 08-16-2010 | 12:32 PM
  #179
Michael#81's Avatar
Thanks guys
Wow, under 7 lbs. How did you do this? I am running the RC8BE and every screw I have in my car is Ti and every nut is aluminum with the GHEA lightweight worlds kit and my car comes in at 7lb 8oz. I am running a 6S 3000 pack that only weighs 412 grams.
I am running almost the same Tekin setup. Here is my setup.
Version 208
Gearing 16/46
Drag Brake - 25
Brake Strength - 75
Limiter - 65
Neutral - 15
LVC - 6
Motor Type - 3 BL/DL
Throttle Profile - TP1
Default TP1 Timing
Michael#81 is offline
Old 08-16-2010 | 12:33 PM
  #180
Michael#81's Avatar
I use the Robinson Racing pinions and they work out just fine with the Elite mount on the RC8BE.
