Team Associated RC8Be Thread
#168
Yup, I need one also. I sent you two e-mails but never received a reply. You must make a nice product to have all the folks here wanting one.
#169
I will make a larger amount on the next batch, the last batch I made 100 RC8 mounts I had no idea it would sell so quickly..
MulliganAl I never received your emails, please email me again and I will have you on a waiting list. this goes for anyone else who is interested..
Email me and I will have you on a reserve list..
Thank You!
Thank You!
#170
elite rc mount lesson learned
my asc pinions will not work with my Elite rc mount. The set screw side of the pinion is too long for me to get the proper mesh with the spur (front to back) I will have to use a losi, novak etc type pinion. Just a heads up for new buyers/installers
#171
ESC & Battery
Well I'm almost finished building my very first 1/8 buggy but I was wondering which battery connectors most of you use with the Mamba 2200 and what size connectors are best?
I was looking at some of the Dean connectors but can't figure out which are best for the 2200.
Also, do you guys wrap your motor to ESC cables?
#172
got my 6s system put in today. ran a few laps here at the house to break in the batteries. the 9oz weight lose is very noticable. thing's got more steering than i know what to do with, pushing is gone. It will almost pivot on the front-end without braking.
What is the lightest weight allowed to run at most races on 1/8 ele.
i should be around 6lb 11oz +/-.
Anyone have some base set-ups for running an RX8,1400kv motor, and 6s 2650mah. I am geared 18/50 until my 17tooth pinion comes in.
Thanks guys
Thanks guys
#175
What is the battery tray width?
#176
Thanks guys
Thanks guys
#177
should be able to make 12 minutes. My buddy is making 12 minutes on 2200mah battery with a different motor setup. I should be ready to get some runtime ideas today.
#179
Thanks guys
Thanks guys
I am running almost the same Tekin setup. Here is my setup.
Version 208
Gearing 16/46
Drag Brake - 25
Brake Strength - 75
Limiter - 65
Neutral - 15
LVC - 6
Motor Type - 3 BL/DL
Throttle Profile - TP1
Default TP1 Timing
