Team Associated RC8Be Thread >
Old 08-16-2010 | 12:35 PM
  #181
Michael#81's Avatar
Originally Posted by jboquire
Hey guys,
I started putting my RC8Be this week and noticed that the manual does not call for any type of lubrication between the crown and pinion gears, is this correct or you guys use grease?.
regards, jb
I do not put anything on mine. Just make sure to shim them to the proper spec and you should be fine.
Michael#81 is offline
Old 08-16-2010 | 01:20 PM
  #182
jboquire's Avatar
Thanks Michael,
I installed one on each side of the bearings per the manual and it seems to be spot on.
regards, jb
jboquire is offline
Old 08-16-2010 | 01:21 PM
  #183
millerdui's Avatar
Originally Posted by Michael#81
Wow, under 7 lbs. How did you do this? I am running the RC8BE and every screw I have in my car is Ti and every nut is aluminum with the GHEA lightweight worlds kit and my car comes in at 7lb 8oz. I am running a 6S 3000 pack that only weighs 412 grams.
I am running almost the same Tekin setup. Here is my setup.
Version 208
Gearing 16/46
Drag Brake - 25
Brake Strength - 75
Limiter - 65
Neutral - 15
LVC - 6
Motor Type - 3 BL/DL
Throttle Profile - TP1
Default TP1 Timing
sorry i got a lil messed up it should be 7lb 11oz battery and all. what battery are you running to be a 412g 3000mah. I am getting 11-12 min runtime with 2600mah. I am also running bce chassis
millerdui is offline
Old 08-16-2010 | 01:29 PM
  #184
Michael#81's Avatar
Got ya. I was wondering about that. I can get right around 15-16 minutes of runtime from the 6S 3000 Pack. It is a WinForce 3000 35c battery.
Old 08-16-2010 | 06:00 PM
  #185
AE-Reedy
Most guys run a little black grease on the gears. I don't think you should run them dry.
Sean Cochran is offline
Old 08-16-2010 | 07:31 PM
  #186
Greasing your gears will only accellerate wear - the grease traps any dirt and makes a nice gritty paste.
Smokey
Smokeyr67 is offline
Old 08-16-2010 | 08:26 PM
  #187
BLbound's Avatar
I run a little associated black grease on mine...my car is super quiet.
BLbound is offline
Old 08-16-2010 | 08:31 PM
  #188
Michael#81's Avatar
Smokey
I agree 100% with this post. I have been running my gears dry in my dffs for a little over a year and never had an issue or a failure.
Old 08-16-2010 | 08:54 PM
  #189
Originally Posted by kaisertrip
I run the Nano Tech as stated before.
But you have to modify the Rc8be tray.
HK has the 6000mah battery at 170mm +
but I actually got a chance to measure them and found this is not accurate. They are roughly 155mm, a tad to long for our trays.
But dammit I want to run these batteries so a cutting I go....
Tray:
Battery in tray:
Sorry don't know how to attach in those nice little boxes that explode!!!????
These batteries are awesome and they are not the best batteries they have. They have some higher "c" rated (dishcharge rate) batteries
The battery tray will hold a 140mm battery(stock unmodified).
I run the 3s batteries I have a four cell same size (length)
why do you run 3s over 4s?
whjdm069 is offline
Old 08-16-2010 | 09:42 PM
  #190
jboquire's Avatar
Thanks to all that responded my question about crown/pinion lubrication.
One more question, should I run 4S or 6S with a Mamba 2200kv ?. There seems to be mixed opinions about this, I will be racing a medium size outdoor track here in SD.
jboquire is offline
Old 08-17-2010 | 08:31 AM
  #191
I think most everyone agrees that 4S would be about the most voltage you would want to run racing with 2200kv.
305997 is offline
Old 08-17-2010 | 08:33 AM
  #192
MCSRacing's Avatar
guys the diff cases on the rc8 have a gasket and a metal to metal gear mesh with no grease is asking for problems ... would you run your corvette with no lube in the rear end ??? just some food for thought!
MCSRacing is offline
Old 08-17-2010 | 09:40 AM
  #193
I just completed my RC8Be with a 2200kv and I'll be using a 4S with a 5000 or higher. I talked with the Castle Creations folks and that's what they suggested.
MulliganAl is offline
Old 08-17-2010 | 09:57 AM
  #194
jboquire's Avatar
I just spoke with ae and they confirmed that no lubricant is required between crown and pinion gears.
jb
jboquire is offline
Old 08-17-2010 | 10:03 AM
  #195
jboquire's Avatar
What pinion are you starting with?. I was thinking 17T.
jboquire is offline
