NOVAROSSI Engine thread....
#617
#618
are you wanting to use the new coated crankcase ?
#619
The reason that I had some hesitation is that I noticed that the back-plate on the P5X has a couple of "dents" in it on either side of the channel where the bottom of the piston sits, whereas the same part on the XL did not, and it then dawned on me that the inside of the engine block was probably channeled differently between the P5X and P5Xs... Hence my wondering if the old P5X sleeve/piston/crankshaft would work or create some sort of power-robbing turbulence.
#620
Hi Monty. The P5XL crankcase I plan to use is actually the bare aluminum one, not the newer black one. I got it off e-Bay because my regular P5X case had a broken back-plate screw shaft stuck in the block and that was the closest replacement I could find on short notice.
#622
#624
Hey guy's I have a question about exhaust, I am running the Toro Nero in my MBX-6 and love it. I am running with a 9901SS pipe and the 41029 short header for the Mugen buggy,my track that I run at is more technical then fast but that being said there is still an 80ft straight on the far side of the track and a few solid jumps. Being that I am still very new to the offroad racing I am wondering if there is a better choice for me with pipe and header selection? I will be picking up the long version of my pipe (41030) for the Mugen buggy but what pipe and header combo would you all recommend to get the most out of my Toro Nero?
Thanks guy's
Sean
Thanks guy's
Sean
#625
Thanks guy's
Sean
Thanks guy's
Sean
That should be a kerazzy buggy engine setup you got there
#626
Sean
#627
LOL yes it is a solid runner thats for sure, but if I was to point one thing out that seems to be lacking it would be the bottom end. Now that being said it only has a gallon threw it at this point and I have not gone far off the stock carb settings since break in (of which I did the heat cycle method) at this point I am 3 hours lean on the low side and 4 hours lean on the high side from stock and with this setup on the track during the tight mid section I feel it is building up and killing my low end thunder.
Sean
Sean
#628
I will add that I am in n o way unhappy with the performance of my setup as I was still able to manage a second fastest lap for the day and a 2nd in the A main at the last club race, I am just looking for ways to get the most out of what I have.
Thanks for the advise guy's
Sean
#629
quick question guys,is the JP3 or 4 header the same lenght as the 41020?
would it work with a 2084ss pipe for better bottom end? I have an extra JP header. Has anybody tried the JP/Nova combo? I'm trying to save a little, I could buy 5 or 6 glow plugs with that dough
#630
U will behappy with your setup , if for some reason you aren't I will do what I can to make sure you are
352Likes
