Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 08-06-2010 | 06:28 AM
  #3586
revo61's Avatar
Originally Posted by Lonestar
Monty, would you also recommend the 086 for the N21RL on a tighter track layout? I thought the 086 was more hi-rpm-oriented...
thanks
Trying mine with 9901 for a maiden race this weekend. it still pinches a *bit* at TDC but it's almost there after 3L+ of fuel. I ditched the POS stock carb though and put my Plus4's on it, the idle screw is a PITA to get to... Hopefully I can find someone to help me tune this baby at the track as I'm really hopeless with engine tuning
Paul
Let me know how it goes for you. I was thinking of using the 9901 with my Hotmods N21R.
revo61 is offline
Old 08-06-2010 | 10:14 AM
  #3587
houston's Avatar
Tech Prophet
Originally Posted by kgombe
what pipe header combo are you guys running on your FMS for truggy... also should i re-shim for 30%... mine came .7
If compression is low leave at .70 , if its pretty good reshim to .80 mm
2084ss/41021 9853ss/41021 if you want more low end grunt but less mileage
houston is offline
Old 08-06-2010 | 11:44 AM
  #3588
jonw's Avatar
Monty
Haven't talked to you since last Friday, Cade has a good race weekend in San Antonio last weekend. He raced in the City Shootou between Austin and San Antonio Texas. Typical Texas heat hovering around 100 all day with dry technical track. San Antonio always does a great job with there races and this one alot of fun.
Cade qualified for A in arena truck and finished 4th at the end of the 30 minute main. The P5XLT was great all day. Cade really likes this motor!
Buggy was different battle all together. Very technical layout for buggies and he worked hard for his qualifying spot and made it in the A but we had fuel line problems during A so it kept us from getting a good finish. Got him back out and he finished 8th. The last 10 minutes he worked on his whips XGames style on their big front double lol. He and Mike Battaile had a little contest going on at the end of the race.
He also finished 2nd with his SCRT10, need to get a nitro version and throw a Nova in it soon!
Thanks for the help as always
Jon & Cade
What do you use to clean the inside of engines before you put them back together and what lune do you use?
jonw is offline
Old 08-06-2010 | 01:46 PM
  #3589
houston's Avatar
Tech Prophet
Originally Posted by jonw
Monty
Jon & Cade
Sweet !! Good job Cade !!
Denatured alcohol then lube with rbmods after run oil
houston is offline
Old 08-06-2010 | 01:49 PM
  #3590
kgombe's Avatar
its brand new.... so i guess i should re-shim to .8.. well that sux..
kgombe is offline
Old 08-06-2010 | 01:52 PM
  #3591
jonw's Avatar
can I use something other than RB Mods? And di I flush the motor out with the alcohol?
jonw is offline
Old 08-06-2010 | 04:22 PM
  #3592
houston's Avatar
Tech Prophet
if you got it from me i reshimmed before sent unless you got a sealed box one
houston is offline
Old 08-06-2010 | 04:24 PM
  #3593
houston's Avatar
Tech Prophet
of course you can but that is the good stuff
you can fluch the engine with raw nitro fuel just the same if you would like
i am pretty meticulous with engine internals ( and i know how to spell )
keep me posted
houston is offline
Old 08-06-2010 | 04:29 PM
  #3594
CWILK's Avatar
could I get the front and rear bearing sizes for the FMS.
Thanks Corey
CWILK is offline
Old 08-06-2010 | 04:31 PM
  #3595
houston's Avatar
Tech Prophet
Thanks Corey
front 7x19x6x6.3mm part # 17011
rear 14.5x26x6x6.3mm
do you need some?
houston is offline
Old 08-06-2010 | 10:24 PM
  #3596
kgombe's Avatar
nah i go tit from a friend... i measured it and it has .7... so i will be looking for some shims..
kgombe is offline
Old 08-07-2010 | 01:03 AM
  #3597
Lonestar's Avatar
Sir? Any idea on this?
Thanks!
Paul
Lonestar is offline
Old 08-07-2010 | 03:57 AM
  #3598
Maximo's Avatar
from everything I have seen putting the shimming up to .8 is going to hurt bottom end not help it...... Maybe I am wrong here, but I have never seen an engine gain bottom end by lowering compression ..... The stock FMS runs a pretty low trapped compression ratio to begin with, if it was me I would be reducing the shim stack, not adding to it if your looking for more bottom end......... sorry to butt in !
Maximo is offline
Old 08-07-2010 | 06:18 AM
  #3599
kgombe's Avatar
i haven't ran it yet so i dont know how it performs.... i just know that novas comes shim at .8 for 30.. so i rather start there get it broken in and if i need more of anything then i just adjust to suit..
kgombe is offline
Old 08-07-2010 | 09:07 AM
  #3600
houston's Avatar
Tech Prophet
I didn't see him say anywhere he was looking for more low end , that wasn't the topic or goal to achieve in this case ? Unless I missed something
houston is offline
