Houstons Engine Service H.E.S.
#3393
The toro team in a buggy is RETARDED !! If that's what youare looking for
#3394
no but i CAN drive it...dude im coming off 1/8 onroad, where my last moto,mr JP Eagle 9 was getting slow for me....but the runtime is that bad? also good to have crazy hp for larger track...
#3395
#3396
well finished the break in FINALLY on the 4c team yesterday...car is sick!!!! a lil more than 2 gallons till her cherry popped, but what a GIFT when it did, so its all worth it,i will run that motor for small club runnin, i just peeped the toro on you tube, THATS EXACTLLY WHAT I WANT, throttle control , and driving it right, will it make the 10 min mark? what about the fms, is it a lil tamer?
#3397
#3398
I would look at the p5xlt if you want alil more top. hahah you crazy !!
#3400
Hey Monty, you got that button in stock now? If ya do I'll pm ya in the morn. Bout to head into work now. And is they any advantages to the Turbo button other than that's what my other motor has and it will be easier with one type of plug?
#3401
Monty, I just bought a "HES" tuned P5XS with a filled crank from a fellow racer. Engine still needs more break in and my plan was a 2084ss pipe with a 41021 header and odo 100 or 99 plugs running byrons 30% does this sound pretty good on a short tight track where the hole shot out of the corner is the name of the game. Lastly I have some GMK supply "Afterlife" aro and wondered will this be alright with your filled crank as it states it is safe to use with silicone ramp cranks. .
Any input would be appreciated.
Thanks.
Thanks.
#3402
Thanks.
Thanks.
I am not100% sure about the gmk stuff , I use the rbmods , its gooood
#3403
#3404
From: 4373 Creek Road Chaffee,NY 14030 USA (716)783-5198
Monty,
Modded N21R ran very nice thru morning and untill steering servo went bad after 2nd qualifier. No problems with engine and ran with very good controlable power. Today added 0.1mm shim, ran 9853/41021 , hot plug, steady 250F temps. Plan to replace steering servo before Thursday night practice and race again next Sat. Found the power band very steady and comfortable bottom thru top end. End resulted same lap times the D8 with modded N21R as my backup buggy MBX6 + B5/2013 combo. Again, Very steady smoothe running engine
Thanks! Talk again
RayAracing
Thanks! Talk againRayAracing
#3405
[QUOTE=houston;7624353]From?
His name is Jerry he goes by teamlosi906; here is the link if you could tell me any thing about it?
http://www.rctech.net/forum/r-c-item...uned-21-a.html
Thank you.
Thank you.
22Likes
