SC10 Thread
#4486
This class has really cought my eye and im really getting an itch to get one, here is my question. I want to build one, not an rtr, but i want to run in a stock class. Is this possible, and if so what can i do. I am leaning toward the associated car but what do i do about electronics,tires, etc?
Like i said i am really likeing this clas but i am confused on how to get into it. Thanks
Use whatever you want for the electronics an tires, nobody races stock (at least not around here).
#4487
If you need to buy electronics I would recommend something with timing advance like Tekin RS or MMP. This makes the 17.5t run faster like a 10.5 on the straights. It is not ROAR legal but most Club or Regional series are not policing this. I know cause I race against guys that have them and they blow by me on the straights.
#4488
Everyone loves the Tekin Pro but the thing is $300. I would go with a Mamba Max Pro and motor which is like $175 after the $20 Tower discount coupon. Both are sensored, USB connectible and have firmware updates
#4490
I race Stock with a Novak Sport 17.5 SSPro system and 40c 4000mAH battery. I am ROAR legal and our local racing series has the ROAR stock class. At Club races I am running a 13.5t in the Open 2wd class so far but the 17.5t is decent on tight tracks with shorter straights. Most Open or Mod SCT 2wd trucks are running the 10.5t motor.
#4491
il give the sc10 thread a lil shot in the arm seams a lil dead latley ,
iv been having a shocking time latley with my st 17mm hex convertion and have not really put a full battery through my sc10 yet
. the problem is , the standard nuts for the rear wheels will not fit in the hub converion . new smaller 8-32 nuts do not come with the kit so im guessing it just relise on the drive pin to hold the hub and wheel on . im not happy with that because it allows the wheel to move and have a lil play . i need a nut to srew up in side nice and snug. being from australia i have a hard time getting 8-32 nuts and the ones i can find dont fit like the standard ones . iv got sum nylon ones coming from amain so hopfully they fit and are small enuff to fit in .
i tapped out a nylon 4-40 nut to 8-32 that my bro had for his rc10gt to see if it would work and it did . but i had to turn down a socket just to do the thing up . hopefully these new nuts work . any one els run these hubs ?????
. the problem is , the standard nuts for the rear wheels will not fit in the hub converion . new smaller 8-32 nuts do not come with the kit so im guessing it just relise on the drive pin to hold the hub and wheel on . im not happy with that because it allows the wheel to move and have a lil play . i need a nut to srew up in side nice and snug. being from australia i have a hard time getting 8-32 nuts and the ones i can find dont fit like the standard ones . iv got sum nylon ones coming from amain so hopfully they fit and are small enuff to fit in . i tapped out a nylon 4-40 nut to 8-32 that my bro had for his rc10gt to see if it would work and it did . but i had to turn down a socket just to do the thing up . hopefully these new nuts work . any one els run these hubs ?????
#4492
i ended up running my sc10 last night , put 2 lipos through it , even with the rear wheel problem i was just hanging to use it
. ran good , jumps great , i think i might need stiffer springs in the front i think its bottoming out a lil . the new chassis was good nothing came loose , broke or cracked . always a plus . i do have a lil problem with engine heat, i think my cars a lil over geared , the engine is cooking . i did run the batteries back to back but still its soooooo hot ya cant touch it . i might re gear it and iv bought the alloy rear engine guard and a heat sink fan set up to go on the motor to keep it cooler . soo il see how that go's.
oh and i also tryed these tyres on the back and on dirt/grass they are awsome
best thing ever ,the thing on thick grass does wheel stands hhaha .. http://cgi.ebay.com/GRP-GMW04A-1-8-B...item5192cd6f17
. ran good , jumps great , i think i might need stiffer springs in the front i think its bottoming out a lil . the new chassis was good nothing came loose , broke or cracked . always a plus . i do have a lil problem with engine heat, i think my cars a lil over geared , the engine is cooking . i did run the batteries back to back but still its soooooo hot ya cant touch it . i might re gear it and iv bought the alloy rear engine guard and a heat sink fan set up to go on the motor to keep it cooler . soo il see how that go's.oh and i also tryed these tyres on the back and on dirt/grass they are awsome
#4493
I've got an SC10 roller on the way to my house. I'm putting an AE brushless 3900kv system in it, you guys think that'll be decent? I'm a complete newb and will just be racing it on my own offroad track, so I don't care about classes or competing with others. The 3300kv in my T4 and B4 are silly fast to me, so I imagine I'll have my hands full for a while.
#4494
i got a question about the rear arm mount/toe block for the sc10... you can buy one with anti squat shims for b4/t4 and the other with rear brace says for sc10... are both the same or totally different degrees .... thnx in advance
#4495
#4496
You can only put so much traction down to a track man. Faster motor doesn't mean faster truck. I would start racing in a stock class 17.5 turn.
