SC10 Thread
Old 06-18-2010 | 01:11 PM
  #4456
Tilden's Avatar
which good tire for dry and loose dirt outdoor? Bowtie XTR or M3?
Tilden is offline
Old 06-18-2010 | 01:12 PM
  #4457
sly6t's Avatar
Default Carbon fiber RACE trucks = finished :)
hi all just a few pics of my custom truck all finished and ready to roll, turned out really good , cant wait for it to hit the track :P .
what ya think
sly6t is offline
Old 06-18-2010 | 01:14 PM
  #4458
sly6t's Avatar
sly6t is offline
Old 06-18-2010 | 01:17 PM
  #4459
Tilden's Avatar
what ya think
Attachment 606360
Attachment 606361
Attachment 606362
Attachment 606363
Attachment 606364
Nice truck, Do you know the part number for Red adapter on wheel?
Tilden is offline
Old 06-18-2010 | 01:45 PM
  #4460
sly6t's Avatar
cheers man ...
STRC-Alum-17mm-Hex-Conversion-Kit-STC9608
sly6t is offline
Old 06-20-2010 | 11:01 AM
  #4461
bjholz's Avatar
cheers man ...
Looks great man! What aluminum part is that in the front, not the rod-type brace, but the part that goes over the steering linkages? Too bad my local track does not allow aftermarket chassis!
bjholz is offline
Old 06-20-2010 | 12:07 PM
  #4462
bjholz's Avatar
Quick question guys. I have a Novak GTB and the specs say "Compatible with all Novak 540-size brushless motors". I am going to be running stock 17.5 class. So I am going to want to get the Novak 540 SS 17.5 motor? Or can I get the Ballistic 550 17.5 motor? What the are advantages/disadvantages of both these motors?
I will be using this in a SC10
bjholz is offline
Old 06-20-2010 | 01:37 PM
  #4463
sly6t's Avatar
Golden Horizon Racing Aluminum Top Plate (Silver) GHH04250 . got it from amain hobbies . i wanted to stiffen the front as much as i can but to be honest im not very happy with the quality of that product . there are a few other companys that make alloy top plates i should have gone for them.the integy one looks alot better.
sly6t is offline
Old 06-20-2010 | 02:34 PM
  #4464
ShortCourseOnly's Avatar
I would recommend that Ballistic 17.5t which is a 540 motor. You will like that with the GTB. No issues at all. I run the Novak SS Pro with the Havoc Sport ESC. I am planning to upgrade the the new Havoc Pro SC and Ballistic 17.5 for our winter series.
The 550 motors are for the 4x4s.
ShortCourseOnly is offline
Old 06-21-2010 | 02:26 AM
  #4465
kneedeeppow's Avatar
Default sc10 17mm adaptors
can anyone recommend a good 17mm wheel hex adaptor for sc10? are the sc racing or aka racing kits ok?
kneedeeppow is offline
Old 06-21-2010 | 01:23 PM
  #4466
sly6t's Avatar
i run the st racing one , got it off ebay and i have to say the quality is top notch. the price is very good to alil cheaper than the rest. the only thing is im not sure if im ment to put a nut on the rear to hold them or is it just held by the drive pin . im not running a nut and it seems to work well , the standard rear nut does not fit inside the 17mm hex hub , im guessing that the drive pin is what holds it.
sly6t is offline
Old 06-21-2010 | 01:35 PM
  #4467
bjholz's Avatar
Whats the difference with the Havok and GTB?
bjholz is offline
Old 06-21-2010 | 01:38 PM
  #4468
RT3's Avatar
RT3
Hi guys and gals. Just picked up a used SC10 here on rctech. Also picked up some Lipos from here from a different user. These are the ones I purchased:
Turnigy 5200mAh 2S 30C Hard-Case Car Lipo Pack
http://www.hobbycity.com/hobbyking/s...dProduct=10277
I noticed afterwards that the wires come out from the end of the battery case instead of the side or top. Anyone else using these for their SC10, and is the wire in any type of danger of coming loose or smashing against anything when being run?
Thanks! Looking forward to running my new truck!
RT3 is offline
Old 06-21-2010 | 02:22 PM
  #4469
mpluis's Avatar
I think you can cut a slot in the foam for it.
mpluis is offline
Old 06-21-2010 | 02:28 PM
  #4470
sly6t's Avatar
do all u guys run conectors between ya esc and the motor ? so you can unplug the motor . or do ya hard wire it straight to the motor . i hard wired mine so i could use nice short wires and make it nice and neat and have nothing inbetwen the 2.
sly6t is offline
