Like Tree18Likes
Xray NT1
Old 04-17-2010 | 02:53 PM
  #5191
meronr's Avatar
Originally Posted by epowr_Racing
Just wanted to share some pics of my NT1 2010 , hopefully can get it on the track this weekend.
Looks great...But they always do when they are new...
meronr is offline
Old 04-18-2010 | 08:06 AM
  #5192
spurcheck's Avatar
Originally Posted by nitrobeast
Jammin Jeff on the xray!!!
Yo Rui,
yep, I finally took the plunge. I am about 2 seasons overdue. I know it is the right decision. Lots of support locally for the NT1. Not sure if the car will be together for the charity event but down the road for sure.
Here is a question, what is the part # and name of the "gizzmo's" that prevent the body from tucking at the back?
spurcheck is offline
Old 04-18-2010 | 08:27 AM
  #5193
rx7ttlm's Avatar
Originally Posted by spurcheck
Yo Rui,
you can use some m3 (hole size) body posts or you can run the xray part number 331340
rx7ttlm is offline
Old 04-18-2010 | 05:42 PM
  #5194
ToysRUsKid's Avatar
what he said.
ToysRUsKid is offline
Old 04-20-2010 | 10:14 PM
  #5195
spurcheck's Avatar
Thank you for your response. Also a nice touch with the alternative "body post" suggestion.
Old 04-20-2010 | 10:15 PM
  #5196
spurcheck's Avatar
Originally Posted by ToysRUsKid
what he said.
Man, you are all over the place
Old 04-20-2010 | 10:26 PM
  #5197
rx7ttlm's Avatar
well that's what people have been running since serpent 710 days to prevent rear body tuck. Xray just came out with a more refined part lol..
rx7ttlm is offline
Old 04-20-2010 | 11:40 PM
  #5198
capricorn diff gears:
is anyone else using them? how are they holding up?
i just removed the lightweight locker from my car and was hoping to shave some weight from teh diffs using these gears.
who sells them in the US ?
mrgsr is offline
Old 04-21-2010 | 12:17 AM
  #5199
Hi John,
Joe @ JPM Racing is the Capricorn agent in Australia give him a call he will happily sell them to you. From my understanding he is retailing all the Capricorn gear. Drop him an email.
Cheers Michael.
Mike 78 is offline
Old 04-21-2010 | 12:20 AM
  #5200
Originally Posted by Mike 78
Hi John,
Cheers Michael.
Thanks Mike they are apparently on order still i was hoping to get them before i go to SA state championships
mrgsr is offline
Old 04-21-2010 | 07:00 AM
  #5201
DS Motorsport's Avatar
I have been using them since the start of this season.
Until now I did a 1000 laps with them and there are no signs of wear what so ever.
I expected to see some wear just like the spur gears or drivetrain pulley's but they still looked brand new.
I use 80K-150K in the front diff and 40K-60K in the rear diff, and I run the car pretty hard.
One of the Capricorn drivers advised me though to replace them after 3 races and use the first set for practice until they break.
DS Motorsport is offline
Old 04-21-2010 | 08:30 PM
  #5202
Riketsu's Avatar
Originally Posted by D-nicest
On my car I have about 4.5mm in spacing in between the graphite on the plates with the stock disk being used. You need to leave some excess space because 1) as the metal on the disk heats up it expands, and 2) the disk doesn't spin perfectly true and may rub up on the pads if they are too close causing more friction=heat. Also, although the KM's have worked great for me, having graphite for the plates decreases the area for the heat to dissipate, so the Disk tends to take more heat. So I'm guessing you may need to back out on the screws some to get rid of your issue. Hopefully that helps.
Diatta, thanks alot for the advice! Last race meet I was able to keep the same brake power throughout the entire day...
I believe it was because I left a bigger gap between brake pads and the contact point between the post and the brakepads was not when the brake arm was perpendicular to the front-to-back. (Hope that made sense).
Riketsu is offline
Old 04-21-2010 | 08:46 PM
  #5203
D-nicest's Avatar
Great news, glad I was of some help
D-nicest is offline
Old 04-22-2010 | 05:35 AM
  #5204
HarKonnenD's Avatar
D-nicest - Hey man how's the Xray running for you? What do you think of the Spec 09 version?
HarKonnenD is offline
Old 04-22-2010 | 05:43 AM
  #5205
D-nicest's Avatar
Hey what's up, you trying to get back out on the pavement or what? lol The 09 spec is good, there are very small changes between that and the 2010, but nothing too major. My current car is up to 09 spec and has been running great for me so no complaints here. Basically you wouldn't be at a lost to get the "now" older version...
D-nicest is offline
