Houstons Engine Service H.E.S.
#2086
Hey Monty,
Can you describe the differences between these cranks would make in a 3 port or 5 port - 15007T, 15009T and your 15009HT
Next question for you is what size is the rear bearing in the N21BF? 25,4 or 25,8 - I am guessing the 25,8 but there is not an exploded parts page any where for reference
Thanks!!
Thanks!!
#2089
Monty gots a question..was thinking about sending my p5 to Jim to get a mod done to it ..should i get a mod and then put the plus 4 crank in there or have them put the crank in there and mod it with the engine.
#2090
#2092
send me your stuff wes , the work will be free , you pay the shipping
and no i wont do that for everybody , wes seems like a really good guy , had a few pm's with him and i am feeling generous today
send me whatever you want and let me know what you wanna do with it ok
my number is in one of the om's i sent ya i believe
#2095
Hey Monty,
Can you describe the between these cranks say in a 3 port or 5 port motor 15007T, 15009T and your 15009HT
Next question for you is what size is the rear bearing in the N21BF? 25,4 or 25,8 - I am guessing the 25,8 but there is not an exploded parts page any where for the motor - Same for the FMS; no drawing to reference
Thanks!!
Thanks!!
N21bf is 14x25.4x6mm
As far as the cranks they are all very similar , the tuned versions are basically hand finished and there is timing advancement and intake duration length ground into the crank opening .
#2096
Thanks Big Guy -
So it is all about timing and duration - I need t learn more about these little motors and the principals ..
I noticed you don't have the RB AR/Oil listed on your site you were showing me - should I just give you a call when I need some?
I'm going to throw that FMS with the different crank into my Truggy to see how it runs - I know the track is short but I am curious to see what it does - which of those pipes/header combos do you think would be the ..um .. tamest of the bunch?
So what bearing is that in the FMS use one of the 16002/4 or is it something different?
#2097
Thanks Big Guy -
the timing/duration has quite a bit to do with the engine , yes sir
FMS bearings :
bearing 1
bearing 2
bearing 3 this is the bearing that was coming in the fms engines
the best front bearing on the market!!
theres one more thats not listed that comes in the toro and now comes in the FMS
stick with me , i can probably show ya a thing or two
thanks jeff,
monty
22Likes
