Team Magic E4 Thread >
Old 12-08-2009 | 10:18 AM
  #2716
Isaac's Avatar
Yea my new friend Cammer has them in his E4. Already got some batts anyway. Just wondering what does and does not fit as far as 5000 lipo packs.
Isaac is offline
Old 12-08-2009 | 11:14 AM
  #2717
Pro10noob's Avatar
Hey Wyd,
Look at my sig
Can't stay away from the E4FS.
1 for indoor,1 for outdoor and a E4RS just for fun.
Love the car.
Easy to set up and no suprices in the corners due to the great balance.
I thing i don't like about the car tho,and that is have to ad weights to it to get it op to 1350grams for the lipo class
cheers Roy
Originally Posted by wyd
Awesome. I know if I still ran touring car I would of bought a 2nd E4FS at the price Wolf had them for. What a deal on the car. I say that price and was like OMG!!!!!!!
Pro10noob is offline
Old 12-08-2009 | 11:20 AM
  #2718
iPearl's Avatar
Ahahaha Atleast you adding weights, rather than trying to loose weight hahaha
iPearl is offline
Old 12-08-2009 | 11:30 AM
  #2719
Isaac's Avatar
Haven't weighed my chassis yet.
Isaac is offline
Old 12-08-2009 | 11:40 AM
  #2720
Originally Posted by Pro10noob
Hey Wyd,
Look at my sig
Love the car.
cheers Roy
Try my way to add weight without using the phyical lead weight...
USE TAMIYA BODY...it will make all kinda weight requirment...(really, I did..LOL)
Pearl...you need to add the E4RS on your sig now. LOL
Solara is offline
Old 12-08-2009 | 02:05 PM
  #2721
Pro10noob's Avatar
Without the body its about 1210 gram
With body its 1315 gram
Need to add 40 grams of weights to get it to 1350 gram.
Used a tamiya body before but don't like the handling of it so i stick to a Mazda 6 or the Mazda 6 speed for indoor and the Dodge stratus for outdoor.
Sad thing about the Dodge is that i need to ad more weight.
Ah well as long as it handles ok and i can have some fun out there
cheers Roy
Old 12-09-2009 | 02:26 AM
  #2722
Hey guys... Can someone give me the part numbers on the fs arms and the rs arms.... I will be picking up a FS soon and will be using it only as a rubber car but carpet and asphalt....
As soneone said the rubber spec arms give more clearance?
Would the fs arms be good for carpet then still with rubber tires?
And are the fs and rs arms f/r or are they only diffrent in the rear? Thanks...
RyeRey521 is offline
Old 12-09-2009 | 06:00 AM
  #2723
Isaac's Avatar
The foam FS arms do not help with the correct ride height with rubber tires. The rs arms lower the car for the correct ride with rubber tires. Doesn't matter if it's carpet or asphalt if you are running rubber tires you want the rs arms. Unless you use short springs with the foam arms. The foam arms are for the extremely low profiles of foam tires to get the correct ride height.
Isaac is offline
Old 12-09-2009 | 06:54 AM
  #2724
Rick Vessell's Avatar
I used the RS arms on all my cars, rubber or foam. The foam arms not only make it hard to get ride height but they also have toe in at the hub. With the RS arms you have more than enough adjustability even on foam tires for ride height, droop, and toe in.
Rick Vessell is offline
Old 12-09-2009 | 07:00 AM
  #2725
Isaac's Avatar
Thank you JS good to know.
Isaac is offline
Old 12-09-2009 | 08:14 AM
  #2726
Jochim_18's Avatar
I have the first generation team magic E4 how can you get clearance in fitting the big Lipo Packs?
Jochim_18 is offline
Old 12-09-2009 | 08:19 AM
  #2727
Isaac's Avatar
2-3mm shims
Isaac is offline
Old 12-09-2009 | 08:21 AM
  #2728
iPearl's Avatar
Which BL motors fit the non 09 E4RS ?
Novak Velocity 6.5 Brushless So far this is the only one that fits mines.
Non of the Speed Passion 1st gen Motors fit mines.
And also what ESC dont hang of to the side Besides Tekin RS series ?
iPearl is offline
Old 12-09-2009 | 08:27 AM
  #2729
Isaac's Avatar
Well I race 17.5 and I think the options with no mods are the Novak and Orion motors. I have a Novak Ballistic as I didn't want to hack on the pretty chassis. Plus I have seen them run and they are plenty for anything else I may go up against.
Isaac is offline
Old 12-09-2009 | 08:30 AM
  #2730
I have my DUO 2 on my E4RS now (same car as yours)...but of course I dremel the side pulley mount (that plastic piece) alot to make the clearence. Just do that....it will work, and so does the mount...
I have my SP GT2 speed (yes, it is hugh compare to Tekin) mounted since day 1 and it is like 1/3 of the speedo is sticking outside the chassis....nothing wrong with that. It won't rub the ground unless you press the car on 1 side and force it to rub the ground...
Solara is offline
