Old 12-09-2009, 09:34 AM   #2731
Pro10noob's Avatar
The LRP motors fit like a glove in there.
Almost all motors with a tampered rear end will fit perfectly.
For th GM you need to remove a little bit of the side tensioner at the motor side.
For the rest i don't know.
cheers Roy
Originally Posted by iPearl View Post
Which BL motors fit the non 09 E4RS ?
Novak Velocity 6.5 Brushless So far this is the only one that fits mines.
Non of the Speed Passion 1st gen Motors fit mines.
And also what ESC dont hang of to the side Besides Tekin RS series ?
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-09-2009, 09:37 AM   #2732
I wanted to try the LRP motors. Thanks for the info!
cheers Roy
Isaac is offline   Reply With Quote
Old 12-09-2009, 02:37 PM   #2733
Trader Rating: 20 (92%+)
Thanks Isaac and JS... Guess I don't need to worry about that... What I'll be getting from you is the older version of the car right? Have you already made changes to fit larger motors? Or what motors were you running? Thanks... If Drew and the guys make fun of the cars I'll tell them they were yours and that should shut them up right lol?
RyeRey521 is offline   Reply With Quote
Old 12-09-2009, 10:10 PM   #2734
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Hey Wyd,
Look at my sig
Can't stay away from the E4FS.
1 for indoor,1 for outdoor and a E4RS just for fun.
Love the car.
Easy to set up and no suprices in the corners due to the great balance.
I thing i don't like about the car tho,and that is have to ad weights to it to get it op to 1350grams for the lipo class
cheers Roy
Nice!!!!!!!!!!!
ST Racing Concepts (STRC)
Old 12-09-2009, 10:14 PM   #2735
wyd
Tech Legend
wyd's Avatar
Originally Posted by Isaac View Post
The foam FS arms do not help with the correct ride height with rubber tires. The rs arms lower the car for the correct ride with rubber tires. Doesn't matter if it's carpet or asphalt if you are running rubber tires you want the rs arms. Unless you use short springs with the foam arms. The foam arms are for the extremely low profiles of foam tires to get the correct ride height.
When I ran at Frederick when you seen my car run I had the FS arms and had no problems getting the proper ride height with rubber tires. Worked out great for me.
Can't wait ti hearhow your car worked for you after you get a chance to run it.
Old 12-10-2009, 06:43 AM   #2736
I actually might try the FS arms at some point. The car would be a tank yet still light. I'm thinking the associated spring carriers as the sit lower.
Old 12-10-2009, 10:28 PM   #2737
wyd
Tech Legend
wyd's Avatar
With the short Tamiya springs and the stock FS arms the car was at 5mm ride height but I could easily run lower if I wanted to. I suggest running the car in stock form til you see how it is. Once you get it dialed in and you feel comfortable then I would try the RS arms and see what it gives you.
Old 12-10-2009, 10:40 PM   #2738
Pro10noob's Avatar
Both of my cars(in and outdoor) have FS arms and are on rubber tires and i had no probs with getting it low enough.
cheers Roy
l===/o\===l
Old 12-11-2009, 06:53 AM   #2739
Ok. I get it.
Old 12-11-2009, 12:43 PM   #2740
Trader Rating: 17 (100%+)
Default E4RS
I just picked up the E4RS 09 with the wolf hobbies steel battery tray. Can someone tell me the max dimensions that will fit in the battery tray without adding spacers? I don't see it written anywhere's in my manual. Thank you, Vinny
vinny73 is offline   Reply With Quote
Old 12-11-2009, 07:48 PM   #2741
Default Body.
I have already read a grip of the 183 pages of this thread. I will be the only one at my local tracks running a team magic car. I really wanna kick their butt. I need to learn to drive better but, well, I still wanna roost them. I am now running a TC3. Please, don't tell me what I allready know!!! Old, worn out, blah blah blah. I'm new and wanted to get something cheap to start. I wanted a new car and this is the one I picked. What is a good body to use for this car? What works? I use a mazda speed 6 body now. But my new car needs a new body. Was looking at the "?Mazda R9?" Kinda like the 6 but a little different. I like it a little bit better than the 6. But only for looks. Can you please give my your opinion or ideas of what works good for this particular car. Thanks, Vinny
Old 12-11-2009, 07:52 PM   #2742
Oh yeah. I will be running outdoors. Medium traction asphalt. Small track. 5 to 6 minute heats. Track is sometimes technical. Thanks, Vinny. Also, running 17.5
Old 12-12-2009, 08:38 AM   #2743
GCT69's Avatar
somebody told me that the arms of the e4's are really weak? please enlighten. I currently drive a tamiya and looking at wolf's price I might be leaning in getting one, anyways, ever since I bought my tamiya ( bout a year ago )I have only broken 1 front arm, and two spindles and 1 c hub. And I do hit the boards in almost every race.
GCT69 is offline   Reply With Quote
Old 12-12-2009, 07:08 PM   #2744
Mazda R9 has BIG steering and unless you are ready for that I would stay away from it. Even the pro don't run that body. LTC or the Mazda. I have the Mazda and it's fine. The car changes direction like no other chassis I have ever owned.
Old 12-12-2009, 07:11 PM   #2745
I ran today and had one good hit and the arms are fine. ALL arms break no matter the chassis. I saw the "X" car today in shambles after a hit and seen others too.
team magic m1b pitdog Nitro Off-Road 447 04-30-2013 09:17 AM
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
Team Magic G4 J_Longbrake R/C Items: For Sale/Trade 0 10-07-2004 07:56 PM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
