JL Racing .12
#2057
I run the IDM versions and think the 4 is faster than the evo 3. There are a lot of good engines right now, but the IDM EVO 4 is at the top of the list. Compared to the premium engines, it costs a bit less and gets better fuel mileage. I don't think you will be unhappy with it.
#2059
Don't know the part number because it comes bundled in an O-ring rebuild kit
http://www.kamikazercracing.com/prod...rod=JLoringset
#2060
Has anyone tried a different Carb in the Evo3 Red Dot?, My carb has seperated at the sleeve (The carb body has come away from the metal sleeve that fits the engine case). I can get hold of an OS carb from a 12tz. I really dont want to purchase a new carb as the whole motor will be replaced in the near future. (By the way, this same thing also happened to my last picco red dot aswell , not very happy with the way it's manufactured, 2 plastic lugs holding the metal sleeve on the carb)
Look forward to responses
#2061
#2063
#2066
#2068
Does anyone know if the Team Titan Vector head will fit the Picco .12's?
http://www.team-titan.com.tw/newprod...sinkhead-e.htm
I keep seeing mixed listings. Some are showing only Novarossi and OS with no mention of Picco, and some are listing it as fitting all 3. My stock head is all scraped up and a few fins are bent from rollovers, so I wanted to replace it and try something other than the stock head(s). The black is getting a bit boring to look at and red just isn't my "thing".
#2069
Hi guy
I have Picco JLR .12 red dot engine.
But I dont understant what pipe is better: picco 2607 or 2651?
What fuel to use?
What fuel to use?
#2070
Hi guy
What fuel to use?
What fuel to use?
by the way the 2607 have been discontinued.
1Likes
will make that novapussy of yours look like a RTR engine
. thank you so much.
Thank you very much!
