Old 06-21-2009, 08:52 AM   #2026
Guys still having alot of issues with this engine, yesterday I ran well attempted to run when the engine would not idle, all attempts from other guys with JL3 failed. It would start but not idle even when the idle screw was fully turned the idle did not rise and the engine died. Some of the guys suggested it was the plug, fuel line, seal around carb which were all replaced on the track as suggestion came up but all failed.
Finally cleaned the hSN to ensure fuel was getting in and not blocked, still it did not work.
After hours of frustration I gave up and left for the day, we also noticed when every time we started the engine and blip the throttle we heard a type of metal pinging sound.
Took down the engine and noticed the Conrod seemed a little burnt/golden and full of oil.
Suggestions????
jelayne is offline   Reply With Quote
Old 06-21-2009, 09:04 AM   #2027
Trader Rating: 21 (100%+)
Check for any play in the crank, and is it going through plugs? If so it probley is the rear bearing.
VA_Racer is offline   Reply With Quote
Old 06-21-2009, 09:17 AM   #2028
Plugs lasting forever, no play
Old 06-21-2009, 09:25 AM   #2029
GREGORY!'s Avatar
play in the rod?have you ever change the rod and the bearings?
GREGORY! is offline   Reply With Quote
Old 06-21-2009, 10:15 AM   #2030
Never changed the bearings but I have not been using the engine long, I have only gotten 1/2 Gallon through the engine, but after breakin the engine has been giving issues.
I did however purchase both bearings but I need to schedule the change, I am getting fed up making purchases for this engine, it is stressing me now
When I broke in the engine I was using a Skyline pipe after the running it around tuning on the track i was told it was not performing well because of the pipe, then purchased the pipe, it was still not performing, then I was told it was leaking so we took it down purchased O-ring set changed all still slow and erratic but workable now it is just not idling.
Now today another driver called me telling me to get the 2651, now it is just getting ridiculous
Old 06-21-2009, 10:18 AM   #2031
Gregory I will change the bearings today
Old 06-21-2009, 10:30 AM   #2032
GREGORY!'s Avatar
i don't know if you read this thread before you buy the skyline pipe.
you must know that picco 12 engine work very well with picco pipes.like 2607-2617 and the new 2651.
now for the rebuild.a happy engine is that with noplay in the bearings,and the rod.you must check the crank pin for wear also.
if you have a good bottom that you can go upper.like compression and look about scratch in the sleeve.
then if you are good there too.then you must check for leaks.something that the picco carbs are known for.
my opinion is that you have a mechanical problem.this metal sound isn't good.i hope that you have not ruin it.
Old 06-21-2009, 11:10 AM   #2033
Thanks Gregory, for all the information
How can I tell if the sleeve is not worn?
Old 06-21-2009, 11:52 AM   #2034
Disassembled Piston and Sleeve
Old 06-21-2009, 01:17 PM   #2035
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
did the motor ever get HOT? looks like its been on some pretty high temps. id check the crank pin for wear and also just change the rod. that rod looks like its been through alot. Man that bites. good luck to u.
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 06-21-2009, 01:24 PM   #2036
GREGORY!'s Avatar
if i am not mistake this colored rod is a sign of a very lean engine.take out the crank and put the rod in the pin.if you can feel a lot of play it's time to replace it.
but before go out and buy new rod you must measure the crank pin.
if you have a digital caliper measure the pin.it must not be smaller than 0.05mm from the nominative diameter.ex the not lower than 4.94mm-4.95mm if the pin has 5mm diameter.
if this happen it's better to change engine,not parts.
Old 06-22-2009, 04:07 AM   #2037
itchy b's Avatar
Just wondering if there is a new jlr in the pipe line??
Any news Sam?
I still have 1 new one to run in but would like to get a backup engine for the pit box if my older one which i blew isnt repairable!
I would have thought that there would be one coming out soon!
I have had the evo 3 for 12-18 months at least!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 06-22-2009, 07:33 PM   #2038
gentleman81's Avatar
im pretty sure the evo 4 is soon to drop. the IDM 4 is already out if im not mistaken.
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 06-23-2009, 01:42 AM   #2039
Uga
Uga's Avatar
Some .hk shops claim that they already have the EVO4 straight from PICCO
http://shopping.rcmodel.hk/product_i...ducts_id=14753
http://shopping.rcmodel.hk/product_i...ducts_id=14755
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 06-23-2009, 06:38 AM   #2040
Maximo's Avatar
Suggestions????
chances are your front bearing is creating a vacuum leak......it loses vacum thru thte front bearing and will not have enough vacum signal thru the carb to idle.... very common with Picco engines these days...replace with a better bearing and watch the issue disapear
Maximo is offline   Reply With Quote
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
