Old 03-05-2009, 08:28 PM   #1906
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Originally Posted by ntc3freak View Post
On the track? So what style of driving would i be using? The same as if i was using a broken-in engine? Or do I need to mantain it at WOT or something? Thanks I need quite a bit of help. I've never broken-in an engine on my own,my current engine was broken-in by the owner of my LHS
If you don't have a temp gun, run it on the track pretty rich for 3 or 4 tanks, as though you are breaking it in, then begin to lean. Keep the bottom rich, and I think they run best at 220 - 240 degrees.
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 03-05-2009, 08:45 PM   #1907
Team Kamikaze's Avatar
+1 You can race tune the engine after running it rich for 4 tanks, that is how easy it is to break in the JL.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-09-2009, 03:59 AM   #1908
ntc3freak's Avatar
Hey guys,how many shims do I need if i'm running 25% nitro?
ntc3freak is offline   Reply With Quote
Old 03-09-2009, 06:39 AM   #1909
keavze's Avatar
i would start with 0.5mm, subsequently reduce to 0.4mm...
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 03-14-2009, 02:35 PM   #1910
gentleman81's Avatar
what should be done to a new engine prior to break in. take it apart and inspect for what?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 03-14-2009, 02:53 PM   #1911
0.50mm total shims.
Old 03-14-2009, 02:55 PM   #1912
Don't have to, but if you wanted to, then inspect for any metal shavings.
Old 03-14-2009, 03:57 PM   #1913
0.50mm total shims.
and the stock evo3 has what shims in it?
Old 03-14-2009, 04:08 PM   #1914
The JL EVO 3 comes shimmed for 30%
Old 03-15-2009, 08:31 AM   #1915
so if i am running 25% do i need to remove any?
Old 03-15-2009, 09:24 AM   #1916
Total of 0.50 to 0.55mm shims on a 25%.
Old 03-15-2009, 05:32 PM   #1917
thanks. so stock shims are fine. i can leave it alone, or remove one?
Old 03-15-2009, 07:36 PM   #1918
Just leave it alone.
Old 03-18-2009, 03:11 PM   #1919
i found out that with the jl3:
when adding shims for higher % nitro, apart from re-tuning... one must reduce the idle air gap.
and one must increase the air gap when removing shims for lower % nitro...
hope this may help somebody...and hope someone can give a technical reason as to why this is the case...
g
gortan is offline   Reply With Quote
Old 03-19-2009, 07:36 AM   #1920
the motor is all about flow of fuel and air. adjusting this balance with lead to having to tune the motor difference. the idle setting is a part of tuning also.
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
