JL Racing .12
#2071
PICCO 2651 is way better, here: http://kamikazercracing.com/proddeta...DM%2FPICCO2651
by the way the 2607 have been discontinued.
Our local racers say that Byron is the best.
But 20% or 30% nitro it's a difficult question...
#2072
I have a original Red Dot brandnew from when I used to race years back and wanted to know how often are you guys changing the rods now or have they fixed that problem since then and if so what's the new rod part#.....
#2074
I'm using 20% wit 12% oil so I should be able to go a gallon???
How soon should I change the rod that I broke it in on?
#2076
you cant find a picco rod nowhere but you can get the Mega zx12 rod will work. http://ashfordhobby.com/detail.aspx?ID=4129
#2077
What is standart carb settings for picco .12 red dot?
#2078
Hi all, Does anyone know if these are still being made?
All the shops have them out of stock
thanks
Jason
thanks
Jason
#2080
Where I can find a conrod for the jl3 THX..
#2082
#2084
http://www.ebay.ca/itm/OFNA-51121-Pi...item416089fd63
OfnaDave on Ebay.
For $70 you get a new con-rod, carb, engine block, and bearings. The only difference between this motor and your current motor is the crank, sleave, shim under the sleave (if you have the tuned version), and the button. BUt all the parts are inter-changable.
Shawn
OfnaDave on Ebay.
Shawn
