Old 03-25-2008, 01:44 PM   #1306
Originally Posted by Maximo View Post
Trust me mate..I am doing nothing wrong LOL !!!!! You never know who you are dealing with on the internet, but I can assure you I am more then qualified to diagnose a leaky carb body !!! I have many customers running modified Picco's and we have had to seal the bodies of a pretty high number of Picco carbs.... The difference between sealed and un-sealed is dramatic to say the least...
Now its still winter where I live..but within the next 4 weeks I hopefully will be able to run some nitro...When I do I will make a video of what these Picco's run like before and after I seal the carb body... I think a few of you are going to be eating some Crow on this one !!!!
Hey Neal,
I know who I am dealing with, Trust me
hello is offline   Reply With Quote
Old 03-25-2008, 02:54 PM   #1307
Picco carbs leak guys !!!!!!! Out of 10 Picco's your going to find 3 with a split carb body that will leak and not tune...... This has been an issue with Picco for years and years..... Nobody has been quick enough to catch it tho !!!!! The seam between the composite carb body and the metal end bell is prone to leaking..you need to seal this seem with JB weld or sealant of some kind......... every Picco any of us run has this seem sealed and all our Picco's tune as easy as any other motor............ If you dont seal this seam the motors can be difficult to tune, as the airleak acts much like a Phantom leak..it will only become apparent when the motors gets fully heat soaked,,,,,,you will chase a tune forever till you seal this seem !!
I would have to say this seems to be true. I presently have 2 picco's (3rd on the way, right Sam? ) and I also was having this same problem. One motor would work perfect and with the other motor, it seems I am always chasing a good tune. Around the base of the carb, would always seem damp. I checked the fuel line everything......
Yesterday I was doing some testing with the "leaky" motor, which funny enough runs better, and I got the motor tuned perfect!! Then just like that the motor starts "hunting". I then did a WOT when the carb shot right out from the base of the motor with only the fuel tube holding it in place.
Now, I know you guys are thinking I did not seat the carb and tighten the bolt properly, but this was not the case. Carb was seated perfectly and the bolt was so tight it could not move anymore.
I don't know if the slide cams that hold the carb in place is worn, but they seem perfect. Anyway, I love my JL so much that I did exactly what was mentioned. I changed the carb seal, seat the carb again, tightened the bolt and sealed it to the block. I did this only last night.
I am happy to see I am not the only with this issue.
All in all, I would still buy a JL anyday.
Mugen Seiki USA
Dennison J is offline   Reply With Quote
Old 03-25-2008, 03:03 PM   #1308
Ffejdat's Avatar
A few guys last summer were having trouble with the carb pinch bolts bottoming out on each other, before they pinched the carb fully, it would feel tight when cold, but when warmed, the carb would fall out. The solution for this is to take the pinch bolts halves out and take a little material off the face or front of each one, in other words where they meet together in the block, this will fix that problem.
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 03-25-2008, 03:06 PM   #1309
Meaning you never did it correctly the first time, Neal is talking about leaking from the body itself, and you are talking about it leaking thru the base seal, that is 2 different leaks.
Old 03-25-2008, 03:43 PM   #1310
Maximo's Avatar
I have seen this in both .21 and .28 carbs.... from the Drake version,Jammin version, As well as the Trinity Wasp Pro engines...... pretty much hit and miss, some will leak some will not... work with 20 of these motors and you will see a definite pattern....
Here is the problem area..I have wrapped a piece of tape around the seam to simulate the bead of sealant...But by no means is the tape the solution... I suggest a bead of JB weld around the seam of the carb.
Maximo is offline   Reply With Quote
Old 03-25-2008, 03:49 PM   #1311
Maximo's Avatar
Originally Posted by hello View Post
Hey Neal,
So we know each others names, that still doesn't change a thing.... I still say I know these Picco carbs very well, and without question this is a huge problem area for many Picco engines.....very easy fix regardless !
Old 03-25-2008, 03:52 PM   #1312
Maximo's Avatar
Sounds like you need to shorten up your cinch rods...they are bottoming out before they clamp the carb tight enough..... take some fine grit paper and sand down the two opposing ends of the cinch....it only takes a little sanding and you will get a much stronger clamp.. This is an issue from time to time with engines, you will see this on many different brands....
Old 03-25-2008, 04:09 PM   #1313
Trader Rating: 13 (93%+)
Do OS TZ carbs fit these engines?? i have a spare carb sitting at home.
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 03-25-2008, 05:09 PM   #1314
Thanks Maximo & Ffejdat for the suggestion. Will do this.
As for the OS carb, sorry it won't fit.
Mugen Seiki USA
Old 03-25-2008, 05:58 PM   #1315
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I have only had one carb leak from the area shown in the picture. My biggest problem has been with the carbs working themself loose from the case.
BTW: Novarossi carburetors fit
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-25-2008, 07:02 PM   #1316
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Do they??? I have seen one trying to be fitted and the rods that support the carburator had to be filled down with a dremel so it would grab the carburator like it should. But I think this was on a IDM engine, so I cant be sure its the same with the JL... Can anyone shed some light on this???
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 03-25-2008, 07:58 PM   #1317
Fits on the JL with no mods. I only wonder if the composite carb provides a more consistant tune as oppose to the aluminum carb. Does anyone know?
Mugen Seiki USA
Old 03-25-2008, 08:01 PM   #1318
I run the IDM engines. I have run it with a Nova carb and I didn't have to dremel anything.
The idea behind a composite carb is that it will not get as hot as an aluminum carb. This will help keep the mixture cooler and help prevent vapor lock.
Old 03-25-2008, 08:08 PM   #1319
Ok, so this is why OS places an insulator on their carbs as well. I did find the the Nova carb stays put because the barrel is aluminum as oppose to the JL which is steel.
Scott, did you notice any performance increase using the Nova carb?
Mugen Seiki USA
Old 03-25-2008, 08:17 PM   #1320
I wonder as well since the Nova carb is taller if it would actually provide the motor with even more torque, since this is what you would do with a natrally aspirated engine. Add "trumpets" over the carb to increase low end torque.
Hummm.... if the same theory applies???
Mugen Seiki USA
Misc Stuff Much More, Xray, GS Racing,Peak Racing Pro Models R/C Items: For Sale/Trade 2 05-27-2007 09:41 AM
FS: Savage hop-ups.THS.Trinity.Hardcore Racing.Robinson Racing.HPI.Hitec factory racer R/C Items: For Sale/Trade 10 06-23-2006 05:17 AM
2006 Hobbytown Oshkosh Off Road Racing Season Opener FREE RACING!!! Zac R Wisconsin & Illinois Racing 18 05-23-2006 11:37 PM
HMS Racing - Sole distributor Nova TOP, REX & JP Racing engines hmsracing Malaysian R/C Racers 58 03-15-2005 09:40 PM
Racing Model Sailboats - Strategy and Racing at its Finest rcinsight Web Links 0 01-08-2005 01:49 PM
