Houstons Engine Service H.E.S.
#617
#618
how much fuel have you ran thru it ? Ive got 1 gallon on mine so far. Just bought some byrons 25% to run from here on out. I ran blue thunder sport 20% for the first gallon. After reading all the posts on this thread I decided to change over to Byrons. My engine is still way tight. Cant wait for it to open up some.
#619
Just over a gallon on my P5xs I got from Monty. Broke it in according to his instructions and tuned it with his guidance. Really makes my Losi 8T 2.0 boogie around the track with the best of them. Did a timed fuel check on a tank today and it ran out just over 15 minutes on our medium sized track. Making Novarossi believers out of a lot of the gang at my track. Thanks for everything Monty!
#620
great choice
#621
you aren't yanking the trigger hard enough
thats awesome jeff
keep enjoying your nitro experience
happy motorin',
monty
#622
Jeepers Jeff! Monty is right. Pull the trigger already. You saw me drive it. I bet it would only go about 9 minutes with me driving it. lol. See you Sunday.
#623
I am trigger challenged I guess. My engine has dropped its' nuts, now I need to grow some bigger ones to keep up. Someone taught me that staying on my wheels is the fastest way around the track. I will "get after it" more on Sunday when the track is watered.
Thanks for the tuning help Erik and Monty. Really hooked on this Nitro stuff. With quality engines and equipment it makes it very enjoyable. I hate to see those guys constantly tuning in half turns. Knowlege goes a long way too.
#624
Byrons question for you Monty.
Their race and Pro Driver blends. I've been running 25/9, I picked up a gallon of the 25/11 to go through on my new Plus4 before I run the 25/9 again. What's the advantage of the lower % lube if any? What are the cons of using a fuel with a lower lube % (Byron Gen2 specific)? Was I right stepping up to the 25/11 for run in?
#625
one question , why dont you run 30% nitro ?
yes you were right in running in with higher lube fuel
monty
#626
#627
Thanks!
Having Looped do a body for me soon in the Frosty theme
Then gonna get Fastlane do a starterbox and wing wrap for me to match the body.
I used to run 30%, I dropped to 25 because that's all I could get at my LHS one day. I didn't see any real difference in the 2. Maybe a touch more power, but I need to learn to use what I have before I go after anymore
I took a 14 year break from RC racing. I've got 4 under my belt this season so far. 1 B-main win to bump and finished 7th in the A at a ROAR series race, 1 last place B finish (after some BAD marshalling, and some bad driving afterwards) and 2 days that ended early for me due to a burnt up steering servo and a broken rod
Then gonna get Fastlane do a starterbox and wing wrap for me to match the body.I used to run 30%, I dropped to 25 because that's all I could get at my LHS one day. I didn't see any real difference in the 2. Maybe a touch more power, but I need to learn to use what I have before I go after anymore
#628
Thanks!
22Likes
