SC10 Thread
Old 05-18-2009 | 08:37 AM
  #1321
BuggyKing's Avatar
Originally Posted by Peli
how do you guys rate the sc10 tyres....we race on a hardpack track in sydney australia...the stock tyres understeer on the front at slow speed into hairpins,and they have 0 sidebite on the rear in the high speed sweepers....
my switches,even nearly bald on the rear of my slash have a ton more grip.....
do i
1: just throw the stock tyres in the bin and work out what hub i can put in the front to allow hex wheels(slash hub,maybe a HPI firestorm front hub,or a tamiya type hub)
2: keep the front tyres on it and work on my setup more with the standard tyres...
3:do the front hub conversion and run epic beadlocks all round with switches...
and also have you guys been going softer or harder in general in yor setup...
sorry,but 88 pages of waffle about sc10 are a bit hard to sit down and read looking for a setup tip...after about 10 pages my eyes glaze over
Yes work on your setup. it seems these trucks respond well to changes. Also you can mod the tires to get them to work and you can add a toe-in hub on the rear.
BuggyKing is offline
Old 05-18-2009 | 10:55 AM
  #1322
whipnet's Avatar
Add me to the list. Just started a kit today. Going with CC 5700 setup with this. Not sure about the servo yet.
I can't wait to see the difference between this and my Slash!!
Great thread!!
whipnet is offline
Old 05-18-2009 | 11:39 AM
  #1323
do i
you can use switch tires made for the slayer..they fit right on the stock rims...and yes on dry track they are better..but on wet track stock tires are better...and then you have the j concepts goosebump tires..they are better all around..
i am cornholio is offline
Old 05-18-2009 | 11:45 AM
  #1324
BuggyKing's Avatar
Great thread!!
Night and day difference between the SC10 and the Slash. But the Slash seems to be a more durable truck.
Old 05-18-2009 | 01:13 PM
  #1325
Default Other Mods to increase traction SC10
Hello every one.
Been "lurking" on this Forum for some time. Recently got my SC10 on the track after owning a Slash. Each seem to have there own merits.
I tend to like the messing with the set up ofthe car more then anything.
As for the SC10, I am running a Vellineon VXL in order to compare it with the Slash I own. Sus is all stock except what is listed below except I used 30 WT Oil instead of the Silicone provided.
I am not the best driver but in search of better traction and bite, I installed ProLine Slayer Switch tires all the way around which I feel improved the traction over the original tires. (Dry Track that is)
I also "Siped" the rear set. That is, cut all of the knobs with an exacto knife both perpendicular as well as horizontal which seems to improve the traction even more.
Also installed a T4 Rear Sway Bar along with GT2 Hubs and Arms. Modified the rear arms so I could attach the Rear Sway bars since the GT2 arms have no provisions for sway bar attachments using RC airplane ball Links. Also using Gt2 arms allows you to change the wheel base a bit. Upper Links are set up long. Camber set at 2 deg rear and 1 deg front with maybe 2 deg front toe out.
I realized there was an option of using LOSI parts but wanted to stay Associated and not have to drill arms for larger Hinge Pins.
I used the following parts below for the conversion.
7932 1.5deg GT2/B44 hubs, X2
7930 GT2 rear arms, X2
7933 Rear Crush Tube X2 ( Alu Spacer between Inner and Outer bearings )
7935 larger bearing, X2 ( Use 2 of the original bearings for remaining 2
bearings in the 1.5 hubs )
7927 longer hinge pin. X2 (This PN# is for all the Hinge Pins)
9273 Plastic Spacers for Hub/Arm/Outer hinge pin, X2
( or use LOSI Shock Spacer Kit)
You will end up putting the rear shocks on the front of the Shock tower in order to keep it from binding. Also compare the distance from the tranny to the bottom shock mounts on the rear arms since the location of the bottom holes are different from original arms. I use the outer bottom shock mounts on the GT2 arms and inner top hole of the top shock mount. If running the rear Sway bar you will have to drill the GT2 arms and add RC airplane Ball joints to attach sway bars.
The differance in traction is VERY noticable. I am not the best driver so I mainly see the increased traction off the line as well as coming out of a turn.
I like the front end soft but will probably try AE Gold Springs to stiffen up the front a just a bit as the front still leans a little more then I like, even with the rear Sway Bar.
Next Mod is to put a Ball Diff in the back as I would like to get better Diff action on the rear to help the back end from sliding even more.
Any ideas on improving the front end a bit with out getting to stiff? I like how realistic the truck looks as the front tires cycle over the bumps.
Also besides the JB Weld trick on the rear tires, are there any oher options?
Hope this helps others out since I spent alot of time trying to find out the details with the Rear Hub Toe in conversion myself and had to make SEVERAL trips to the local hobby stores tracking all the PN# down.
Ken F is offline
Old 05-18-2009 | 01:15 PM
  #1326
ldivinag's Avatar
what's this JB weld trick???????
ldivinag is offline
Old 05-18-2009 | 01:27 PM
  #1327
The rear rims tend to strip WAY to easily where the Axle Pin slips into the rear rim. The pins starts to spin and hogs out the alignments slot on the plastic rims.
What I do is fill the cavity on each side of the Alighnment slot with JB Weld to give it more material. Works OK but I have managed to strip a wheel that I modified with JB Weld last weekend. Short of new rims all the time, there is no other option that I am aware of. U should also use a small Allen wrench to hold the axles in place behind the wheels when tightening the rear rims so you do not put undue stress on the plastic wheels when tightening.Also check the rear bolts as often as possible to make sure they stay tight.
Ken F is offline
Old 05-18-2009 | 01:47 PM
  #1328
Originally Posted by charly71
sti821 from youre post above it sounds to me like you would like to maybey see youre track put a limit on the sc10 class? its plain and simple you guys are having to play the tire of the day game at youre track. unless im misunderstanding youre post mabey you guys should talk to youre race director and put a tire limit for the class at my track open corr class is what ever esc/motor you whant and can tune youre suspension anyway you need but the tires must be a corr type tire wether its a sc10 or slash/proline tire they havent decided on letting us run goosebumps yet. sounds to me like you guys need to be running the sc8 at youre track hey if its an open corr truck class then the sc8 is in RIGHT? LOL.
I will talk to the guys and see what gives. We do run SC8's and that is what lead us down the SC 10 path. Most of us run both classes. Even the top buggy drivers are getting in on the Mod slash/SC 10 class. I know it is going to be an uphill battle to try to limit what tire you can run. But it would even things up a lot and keep the price down too. MacRacing better be on board!
Let you know what happens next week after the race this week.
Bob
STI821 is offline
Old 05-18-2009 | 02:21 PM
  #1329
BuggyKing's Avatar
the JB weld trick is to fill the holes on either side of the hex area. This help prevent the hex from stripping.
Old 05-18-2009 | 02:53 PM
  #1330
mcdonaldsracing's Avatar
Bob
Hey Bob, why don't you just step up your game and try to keep up Besides, I'd be pissed if they set limits on the tires we could run after I've spent close to $300 on tires, wheels, and adapters over the last month and a half. I don't have a problem with the prolite class being unlimited. If you don't wanna spend the money (which I know you already have), then just join me in the spec class. I have just as much fun running in the spec races as I do in the prolite races
mcdonaldsracing is offline
Old 05-18-2009 | 05:03 PM
  #1331
KidAgain's Avatar
KidAgain is offline
Old 05-18-2009 | 05:06 PM
  #1332
KidAgain's Avatar
The stock tires modified do pretty well on indoor clay tracks, I dont see a reason to spend extra $$$$ on tires, BuggyKing and F N Cuda grant it good drivers can lift the front right tire off the ground through corners and stick it like its on rails.
KidAgain is offline
Old 05-18-2009 | 05:32 PM
  #1333
ldivinag's Avatar
are the other cars in the AE stable using the roll pin thing?
no hexes?
ldivinag is offline
Old 05-18-2009 | 05:41 PM
  #1334
bcrazy's Avatar
no hexes?
Only hex on a 10th scale AE electric off road car is the front of the B44. Roll pins are on the rear of all electric AE off road cars.
bcrazy is offline
Old 05-18-2009 | 05:52 PM
  #1335
in my opinion 12mm hex hubs like on the kyosho sp/fs and hotbodies d4 should turn into industry standard much stronger with todays brushless lipo systems. but then we are talking new molds for wheels. you know
charly71 is offline
