SC10 Thread
#1171
Started building last night. Steering Rack went together no problems (once I got the Bolt lined up right). Got to the Diff section - Bugger
only one 5x9.5 Outdrive Shim! You can't even get the kit in Aus yet, let alone spare parts. Do AE or someone else make shims the same size for another kit, or will I have to buy the Diff Outdrive Rebuild Kit from the US?
I suppose it'll give me some time to work on the body.
#1173
Thanks Looney. The LHS only had 100 or 200mm, so will get the 200mm.
as for the shims, look up on rchobbies or such...theres bound to be a listing for shims that will suit
#1174
#1175
Well i installed 2deg xxx LOSI carriers on the rear with new hinge pins.
Here is a pic 2deg is on the right, It was a very simple mod the only thing you lose out on is the short to long wheel base adj. If some one wants the p/n to do the mod i can post them lmk.
Erik
Erik
#1176
I ordered the 1 degree Losi hubs and hinge pins, I'll be sure to post them up as soon as they arrive. Are your shock caps OG Gold units?
Also dug through the parts bin and found an old Losi body to use as a chassis cover. I also added some styrene shields to the front of the chassis. I'll post up pics tomorrow.
#1177
Truck is done i will post pics of it with both sides done in a little bit.
#1180
Ok, I'm almost finished with my SC10 build, pics coming soon after I finish. I just bolted on Cuda's front brace (thanks for such a sensical product Cuda!
) which really strengthened up the front nose section of the chassis.
One thing I did notice:
http://www.hobbypeople.net/gallery/383287.asp
I'm a kit person, but I would've bought this just for the painted body (I'm a lousy painter of bodies). But honestly, looking at the "items needed" section, the use of "RTR" seems a little misleading. If you need a radio, battery, charger, motor, and ESC to make it run, it really should've just been labeled "Preassembled" rather then an "RTR".
"ARTR," Almost RTR would've been appropriate too...
Just my $0.02
Ok, back to my SC10 build...
) which really strengthened up the front nose section of the chassis.One thing I did notice:
Just my $0.02
#1181
Items Needed
- Battery pack (6 cell)
- Battery charger (peak detection charger recommended)
- Eight (8) AA batteries for radio
#1182
Just my $0.02
Just my $0.02
Based on the 6-time ROAR National Winning RC10T4, the engineers behind the doors in Area-51 made the SC10 both, all show and all go!
The SC10 comes ready-to-run with a factory finished short course race-truck body, short-course style wheels and aggressive tread multi-terrain tires, all that have been designed to look just like the full-size race trucks that run in short-course off-road series around the country. The world of high-performance 1:10 scale electric R/C has never before seen this level of scale accuracy! At first glance it’s easy to see that the SC10 is another champion by design!
SC10 RTR Features:
Built on the 6-time National Champion RC10T4 platform
Authentic short-course replica racing truck body
Short-course style wheels and aggressive tread multi-terrain scale tires with re-enforced sidewalls
Realistic bumpers front and rear for maximum durability
AE logo mud flaps
2.6:1 ratio gearbox equipped with sealed gear differential
Efficient dual-sided, externally adjustable slipper clutch
Molded composite low-CG chassis
Hinged battery hold-down strap fits NiMH & LiPo battery packs
Set-screw secured antenna tube
Durable front and rear body mounts
14 rubber-sealed ball bearings
Rugged steel turnbuckles for quick and easy suspension adjustments
Fully-adjustable suspension geometry
Angled bellcrank “coplanar” steering with integral servo saver
Vertical ball end roll-center adjustments front and rear
Blue aluminum shock bodies
Steel rear dogbone drive shafts
XP2 radio system with metal gear steering servo
XP SC200 digital electronic forward/reverse speed controller with optional
LiPo low voltage cut off and optional reverse lockout Reedy 17-turn motor
Many Factory Team & Reedy option parts already available!
#1185
[QUOTE=tom_chang79;5789428]Ok, I'm almost finished with my SC10 build, pics coming soon after I finish. I just bolted on Cuda's front brace (thanks for such a sensical product Cuda!
tom, great to meet you last nite and good to see you at the track today.
Glad you like the brace, few more people grabbed em up today at the track.
Looks like the word is gettin out and the response is all positive.
We even installed a couple for them!
Thanks for supportin you local F N CUDA. Very much appreciated!
OH YEH, JUST SAY NO TO EBAY HACKS TWEEKIN THE IDEA AND PIMPIN COPIES.
TELL EM YOU KNOW CUDA DID IT FIRST!
Keepin it simple and effective, been runnin it now on a broken chassis since the trucks first came out weeks ago.
Get yours and just worry bout drivin and not breakin.
) which really strengthened up the front nose section of the chassis.tom, great to meet you last nite and good to see you at the track today.
