Go-Tech Engines Thread
#6542
Ok started my break in of my 21 PRO Go-Tech 7P+2.
I let it idle for two tanks with the temps on the head never exceeding 160 F with a average of maybe 145 or so.
The exhaust header had a max temp of maybe 175F right next to the exhaust port on the engine.
Through this whole 2 tanke I had to tip the buggy over to get the excess fuel out of the pipe because it was wanting to pool up in there.
To add I am running ODNNELL High Performance 30% racing fuel throughtout the entire break-in process. This fuel seems to burn much better than the fuel (traxxas 20%) I am used to in my Traxxas vehicles. (yes I am a recent graduate from the rtr crowd but yet I still ove my Slayer)
I have a few questions about my motor. I am unsure if it is the newer style. Where exactly do I measure at to get the correct reading.
What carb restrictor should I start out with. I will be using a Dynimate Platinum 053 pipe, I was thinking maybe the gold 6.5. Till I learn to drive the beast well. It came with a black plastic one, orange 6.5, silver 7.0, blue 7.5, and the red 8.0.
Secondly what does it mean by 7P+2 I thought it was just a 7 port engine. Are there different ones.
I did take the engine apart and clean it but it looked very good. I would of been ok to not of even doing it.
Lastly I am going to have to wait till I finish assembling the new buggy to proceed with the next steps of the break in procedure. Is this going to hurt anything. I did afterrun procedure and used afterrun oil.
#6543
#6544
Warranty question:
The part of the case that are screwed to the engine mounts has snapped off on both sides. I bought it in late February and didn't run it much (it was in my truggy, which is more of a backup instead of my racer). Does anyone know if this covered by warranty?
I'm asking this question on behalf of the person who bought the 7-port from me. He didn't ask me to check into warranty or anything, I just feel bad that it happened not even a week after buying it from me.
.Let me know how you go with it
Cheers MM
#6545
Yeah 69er you should have got it up to 190-200 and just threw it on the ground and started driving it around in circles but just give it 1/4 throttle for like 2 more tanks. That ide you did at them low temps wasnt too good for the internals but just keep it close to 200 as you can at least I know it can be hard at 1st. just lean the low end needle a few hours after you start it and get it warm then lean it 2 hours or so check it and get it hot. But drive it around to get it hot dont be scared to get the motor warm. Just at the 2 gallon mark do what I said with the rod pin clips and if you want them TKO's you was talking about. By idling it at them low temps your mill will lose its mechanical pinch sooner now but you didnt kill it or anything so dont worry.
#6547
Ok maybe you are lucky , please run the engine hotter from now on . Just put it on the ground and begin to play with it
Cheers MM
#6548
i have a go 7port turbo .21 My question is that my case broke on both sides. i was going to replace it but the case is different
than any gotech ive seen on the case is only a G and the other side as R21, not GO and B21 like the go tech. i have found a website with my case but now im confused anyone help
#6549
What's the difference between a sleeve with and without those relief ports? Thanks!
go go go!!!
#6553
I'm trying out a Race 3 Port. I was curious what pipe works best on this engine (Runtime Mainly)? I have JP1, JP3, DYN 053, GO 2047, and the Redline Pipe that came with the OCM Redline Motor awhile back. Also, Which carb restrictor would give it the best overall mileage without sacrificing too much power?
Thanks!
Thanks!
#6554
Thanks!
Thanks!
i believe the redline is the 0801 pipe and that will work fine... jp3 would be ok not great ..... o53 would chock it up and 2047 would be good choice thnx will g
2Likes
