Like Tree2Likes
Go-Tech Engines Thread
Old 04-27-2009 | 08:07 AM
  #6496
Yeah the Trinity pipe I been wanting to try it out. I have officialy switched to OD plugs I like them and they are 1/2 the price of the OS P3 I was running.
malik is offline
Old 04-27-2009 | 08:21 AM
  #6497
will g's Avatar
yeah i really like them not only for the price but they last long time too. what fuel you using right now?
will g is offline
Old 04-27-2009 | 08:27 AM
  #6498
I have one of the original Go 3Pt "race" spec engines from just over a year ago. I gave up on it due to being new and confused by the backwards way of tuning. Well, my main engine is leaking from the front bearing so I decided to dig up and restore, re-lube and completely seal the Go.
I just put a tank of fuel through it on the ground. It stayed running, pretty nicely actually, but just a few questions.
The tuning philosophy for this engine is to set the high end and leave it, then work around the low speed needle until you get it right... right?
I'm amazed that this engine kept so much compression after sitting, disassembled on a table in my basement. As such, I don't really expect too much out of it, but just a pleasant surprise. Going to try to keep this is a back-up if I can figure out the tuning on it. I do not want to get a carb from a different manufacturer, as I'm not particularly interested in incurring cost.
Semple is offline
Old 04-27-2009 | 08:48 AM
  #6499
will g's Avatar
i would say try the settings on the 3 port at flush on top and bottom needles and run couple laps and bring it in and just keep eye on temps but that where my needles are and it comes off after 10 mins around 235-245 race temps thnx will g
will g is offline
Old 04-27-2009 | 08:52 AM
  #6500
zJatoRad's Avatar
maybe you're still running the long LSN, try getting the shorter one.
zJatoRad is offline
Old 04-27-2009 | 09:15 AM
  #6501
Yeah, I'm pretty sure it's the old needle. Is it even worth trying to run it with the old needle?
Semple is offline
Old 04-27-2009 | 09:29 AM
  #6502
zJatoRad's Avatar
well there was nothing wrong with the old style needle, the way it tunes is different, but the newer style makes it tune like most engines.
zJatoRad is offline
Old 04-27-2009 | 09:46 AM
  #6503
I just ran another tank, it seems as though adjusting the top end makes it act funny and kind of sound like a lean bog. I just kept leaning out the bottom and it kept getting more and more punch. It seems the bottom controls the entire RPM range?
Semple is offline
Old 04-27-2009 | 09:49 AM
  #6504
will g's Avatar
if it has the long needle the needle setting is very fine where is the needle at on both top and bottom ?
will g is offline
Old 04-27-2009 | 09:58 AM
  #6505
When the tank ran out it was at 1/2 turn in from flush on the HSN, 2 turns in on the LSN. Still a lot of blue smoke and running at about 200º. I tried both at flush and it acted so rich that it wouldn't even stay running.
Semple is offline
Old 04-27-2009 | 10:35 AM
  #6506
will g's Avatar
so its running better there ? sounds pretty good any hesitation or anything
will g is offline
Old 04-27-2009 | 10:46 AM
  #6507
It runs really well at those settings. Doesn't hesitate. I blasted it wide open throttle, stopped dead for 5 seconds, and pulled the trigger to full throttle, no hesitation.
I'll lean it out some more next time I get a chance to put some more fuel through it. I guess I'll keep leaning the LSN...?
Semple is offline
Old 04-27-2009 | 11:12 AM
  #6508
TBIRDOWNER86's Avatar
Wink go tech
I have a go tech 5 port for sell. It will need a piston and sleeve. I've had it about a year. I have had trouble locally getting parts. I am getting an engine that is locally supported. ordering parts and waiting on shipments takes too long. If you want to buy call me 678-230-4679. I will take paypal and checks. I will take trades, for hitec servos. I live in Stockbridge, GA
TBIRDOWNER86 is offline
Old 04-27-2009 | 11:33 AM
  #6509
I realize you asked for someone to call, but would you mind PM'ing me what you are asking for it?
mthird is offline
Old 04-27-2009 | 12:10 PM
  #6510
Default clueless
Mthird,
When comes to computers and texting I am clueless. I don't know what pm, bump, ping, etc., etc.... means. I'm sorry.
