Go-Tech Engines Thread
#4996
i ran my 3 port race motor with the go 0801 pipe and man it was flawless. i ran against tons of p5 novarossi's and v specs and siros and was able to keep up not only in the rough stuff but in the straights no problem. very very happy with motor and especially since i was able to keep up with the named motors. thnx go engines and racefactor
will g
will g
#4997
If I replace the connecting rod after a GO engine break-in (around 1 gallon or so), is it a good idea to replace the wrist pin as well? I imagine stress gets put on it as well, and for $3.00, why not?
Thanks!
This refers to my post above:
Thanks!
I was breaking in my 3-port sport today...first break in I have ever done. I was using a combination of the heat cycle method and the instructions that came with the engine. Unfortunately, the engine was much too cool - around 160 degrees. I have only idled my way through three tanks of gas so far, no real throttle yet, and no driving it around on the ground. LSN was flush, HSN was about 2 turns out from flush which is probably what contributed to the ultra-low temps (That and no foil around the head).
Have I already screwed my engine forever, or if I make sure that the rest of the break in takes place around 220-240 degrees or so will that help? I still have about 10 tanks to run through it as I slowly lean the engine out to make power.
I guess I learned my lesson (and found the break-in instructions on page 78 of this thread). Just wanted some input from people who have done this a lot! At least it wasn't some $400 mill, I guess.
Thanks!
Thanks!
#4999
Thanks GO and racefactor. I have loyally used Go engines from the beginning of my racing adventure and hope to have many more wins with the. +1 with Will G. Go engines by far capeable of domination other engines I cant wait for the ebm5 engine for my truggy. I am doing bearings and con rod and pins and clips in mine as per Russell to keep my 5 port (5+ gallons) in tip top shape. They are the only parts I need at thie time. I am only doing it cause the fromt bearing is starting to suck air and after 5+ gallons and that is fine with me that engine has spun prob 2,304,000,000 full rotations in its 128 tank life (think about that for a second) it is a rough guess as i did the math in my head so... anyway. Go engines and Russell of Racefactor are whre my loyalty will continue to stay. Thanks Russell I ran both my Go's this weekend and the 7 port is a monster in the buggy I love it and the bearing gave up the ghost in the 5 port in truck. Oh well Ill get em next time. Thanks again Darrin @ Brujeria Cutsom Graphixxx
#5000
here is some footage of my car with the 3 port race and vp tires (strikers) my car is the yellow, orange, and blue body with yellow wheels and wing starts at the 3min 20 secs very strong running car and motor. first night out for the jammin x2 conversion buggy with the go engine 3 port race and the tires stuck nicely as you can see 95 % of the time. thnx again go and racefactor also vp tires for some great tires will g
http://www.youtube.com/watch?v=I4emO4A7vUc
#5001
Does any Go dealer have this Go items in stock:
-GOT28-0600 - Go Technology Connecting Rod
-GOTGO-W001 - Go Technology Piston "G" Pin Snap Rings
-GOTGO-1500 - Go Technology Carburetor Setting Pin (and does this use o-rings?)
Thanks!
Thanks!
#5002
Thanks!
Thanks!
I am running my 3 port sport I modded a while back next weekend. I only ran it for a couple tanks and it kept up with my sons 5 port but I've never raced it.
Rex
#5003
#5004
congrats wiggle worm on the new position!
Why not come down to LIR this weekend for electric trophy race this sunday!
let's catch up. tryin to get some ct boys in the house and maybe mike will emerge from the lab
#5006
You should come up here.
#5007
trophy race at lir with some sick competition vs a dusty closet where you break every other lap......hmmmmmmm, no thanks. but I knew you would weezle out of comming down to get slapped up. congrats on your position again, represent radio raheem!
#5009
i was there last weekend too racin my go 3port, i was pullin from EVERYONE in my class with this engine i love it. i got it used and idk how many gallons are on it or anythin so im prob going to tear it down once i install my grp in my 2.0 8ight and replace all bearings and stuff and use it as a back up. i may put it in my truggy instead
can you tell me the oven trick
2Likes
