Like Tree3Likes
Tamiya TRF415
Old 03-27-2009 | 10:46 PM
  #20356
STLNLST's Avatar
The car is ready for some more action in the morning. I'll update you guys sometime tomorrow night.
STLNLST is offline
Old 03-29-2009 | 09:12 AM
  #20357
ok thank you for the set up
i tried it and it worked well
white front springs and 50WT oil
Blue rear springs and 35WT oil
25mm droop and 1.5 camber all round
front toe was 0 degrees
there was low grip due to rain in the morning ( i chickened out of that !!)
but it had dried by the second race and the car was planted and i feel i had the most grip i have EVER had with this car !!
big thank you to you all
sidecarphil1 is offline
Old 03-29-2009 | 05:47 PM
  #20358
penmark67's Avatar
Default Great
Excellent just PM me anytime , ive been working out issues on my car for two years now and have a stack of my own setup sheets.
Cheers Mark
penmark67 is offline
Old 03-29-2009 | 10:49 PM
  #20359
STLNLST's Avatar
Car was awesome yesterday. I made a bad mistake in the main and it cost me a chassis, rear hing pin, caster block, and some braggin' rights I have some ideas on what to do to make the car better then next time out so I can't wait until then. The Reedy warm up race is gonna be fun.
STLNLST is offline
Old 03-30-2009 | 01:03 AM
  #20360
piccys please
Old 03-30-2009 | 01:05 AM
  #20361
Cheers Mark
what do you do for a wet set up ??
i want to have a 19 turn motor/waterproof speedo ready for a swap if bad weather comes in
but suspension is a mine field
Old 03-30-2009 | 02:28 AM
  #20362
penmark67's Avatar
Default heck
Man...........I would leave the front alone and probably go reds on the rear
that would help with it swapping ends then go down one spring rate at a time on the front until you get a enough steering ( Im hoping you are using a spool) I would probably run sorex 22's leave the oils alone , leave your front toe as is and maybe raise your front ride height by 0.5 only if its a bit nosy.
Good luck
(ps Im trying 416WE arms and mounts soon ,will post my findings and if lap times were better or worse)
Old 03-30-2009 | 08:15 AM
  #20363
yes i am running a spool
i learned the one way is ...................erm.................... shall i say not good for a brushless set up LOL
i will be using the Vtec dunlop D20 wet tyres as i'm allowed to use 6 sets of tyre per year and with only 6 races i think i can manage with 5 Vtec 27's and the D20's
do you use roll bars on your dry car ??
i got them front and rear , althought they are just the stock ones
my lap times were 2 seconds a lap better than i have ever done , thanks to your set up
Old 03-30-2009 | 08:47 AM
  #20364
f1larry's Avatar
Does the 415msxxx spool work on the TRF415? Also is there a way to make a front diff for the TRF415?
f1larry is online now
Old 03-30-2009 | 08:58 AM
  #20365
hi there i bought all the parts needed for the TRF415 spool and yes they all fit
i have a list of parts ere :-
http://www.vellrip.com/store/product...asp?p=337&c=78
http://www.vellrip.com/store/product...asp?p=742&c=78
http://www.vellrip.com/store/product...asp?p=744&c=78
then you need 3 screws and 2 pins (like the ones in the driveshaft UJ's) and your off
dont use a front diff i didnt like it and the conversion kit it expensave if you find a shop with any
Old 03-30-2009 | 09:06 AM
  #20366
STLNLST's Avatar
piccys please
Pics showed up on the Reedy rac thread
STLNLST is offline
Old 03-30-2009 | 10:42 AM
  #20367
JamesArluck's Avatar
Clint- The blue tang clan is gonna pull your card if you keep making the car look bad like that...
JamesArluck is offline
Old 03-30-2009 | 10:50 AM
  #20368
think it will be out of action for a couple of weeks LOL
it looks bad what happened ???
Old 03-30-2009 | 12:01 PM
  #20369
STLNLST's Avatar
My original crash only broke the front caster block but since the crash happened at the end of the straight and cars were still coming I got hit from the rear and that's were all the damage came from.
STLNLST is offline
Old 03-30-2009 | 12:08 PM
  #20370
i broke a suspensoin arm and the upright at the weekend when a bloody marshal put a late car on the grid in front of me and "turned it on" but actually turned it off !!!!
i hit him full power didnt see him because the start marshal was stood in front of it !!!
got a blinding start from the back of the grid too !!!!
