Old 04-03-2009, 02:48 PM   #20386
Originally Posted by tc3team View Post
can anyone tell me what the measurement should be for both anti roll bar turnbuckles is, as I cannot find it listed in the build manual?
I've noticed that mine have been binding slightly on both front and rear driveshafts.
thanks
front and rear are 15.5 but mine are longer to give maximum movement on the other arm
sidecarphil1 is offline   Reply With Quote
Old 04-03-2009, 02:50 PM   #20387
just set the fastest lap in stock practice tonight with my TRF415MSXX MRE !!!
19.440 lap , the new Xray009s were doing 19.670 and 19.840
YES GET IN !!!!!!
Old 04-03-2009, 04:15 PM   #20388
tim fry's Avatar
Hi all
Just picked up a used MSXX and I'm looking for a base setup for carpet with rubber tyres and one for smooth medium grip tarmac. I have had a look on Eds site and not sure which ones I should pick.
tim fry is offline   Reply With Quote
Old 04-03-2009, 04:52 PM   #20389
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by tim fry View Post
Hi all
Flip a coin and go with it
STLNLST is offline   Reply With Quote
Old 04-04-2009, 12:24 AM   #20390
Hi all
my outdoor set up
white front springs and 50WT oil
Blue rear springs and 35WT oil
25mm droop and 1.5 camber all round
front toe was 0 degrees
front sway bar only
using Vtec30's
droop is measured using the david junn meathod
and i'm faster then the new XrayT2 009
Old 04-04-2009, 07:09 AM   #20391
penmark67's Avatar
Trader Rating: 14 (100%+)
Default yep
YES GET IN !!!!!!
Hi Phil
I said it was a good setup our home tracks are similar , if you do the mods we spoke about you can take out 0.5 deg from your rear toe and no-one will catch ya down the straight HAVE IT
Go getum
Mark AUS
penmark67 is offline   Reply With Quote
Old 04-04-2009, 07:20 AM   #20392
Originally Posted by penmark67 View Post
Hi Phil
Go getum
Mark AUS
i have removed the screw from the motor mount but not the mount mod
i really couldnt bring my self to cut the MRE
but foooooooook does it go around corners i stuffed it down the inside of 2 Xray009 drivers and a HPI cyclone TC
Old 04-04-2009, 08:08 AM   #20393
tc3team's Avatar
is 15.5mm the full length, from end of the ball joint, to the end of the other ball joint, yes?
thanks
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 04-04-2009, 10:21 AM   #20394
Hi
Looking to get back into tc racing, I picked a used 415msx of rctech. Where is the best place to go that summarize all that I need to know about this car. I'll be racing carpet foam w/ 13.5 brushless. And possilbly parking lot too. I use to race with a tc3 and I see that this is a different animal. All help will be appreciated.
LJae is offline   Reply With Quote
Old 04-04-2009, 10:24 AM   #20395
thanks
it is the length of the turnbuckle (between the cut down ball cups)
Old 04-04-2009, 01:31 PM   #20396
tim fry's Avatar
my servo saver seems to be sticky should i replace with a kimborough or just get another Tamiya one?
Old 04-04-2009, 02:06 PM   #20397
tc3team's Avatar
get the small Universal kimborough one and be done with it, (got mine from demon) i've had mine on my ta05, then the 415 for about 2 or 3 seasons and had no issues with it at all, fit and forget
The tamiya ones are renowned for slop and poor fitting.
Sidecar phil, thanks, i'll see what I can do with mine
Old 04-04-2009, 02:11 PM   #20398
just looked in the MSXX book not the MSX and it say's 16mm not 15.5 like the early cars
just had my new DX3S stop working today !!!!!
Old 04-04-2009, 06:13 PM   #20399
STLNLST's Avatar
Originally Posted by LJae View Post
Hi
www.thard.co.uk/415
Old 04-05-2009, 01:44 AM   #20400
penmark67's Avatar
Default setup
Hi
Hi mate , I ran a 415 on foams at an indoor venue and ran 37s on the front and 40's rear schumacher 32lb front springs and 28lb rears 50wt f and 40wt rear 3 hole pistons short camber links and middle hole on the bottom of the arms front and rear 1.5 deg camber f&r 1.5 deg toe out front and 2.5 rear toe in 4mm ride height 3mm droop
I ended up running 2 top decks to stiffen it all up ,
Ps all depends on the type of carpet ur running on
Cheers Mark M
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
