Like Tree2Likes
Go-Tech Engines Thread
Old 03-15-2009 | 11:48 AM
  #5971
7x19x6 front and 14x25.4x6 for the rear. I just put a set in my 5 port . Smooth as butter.
malik is offline
Old 03-15-2009 | 12:01 PM
  #5972
losi_alaska's Avatar
I am lucky, I am going to throw it on the break in bench and get-er -done
losi_alaska is offline
Old 03-15-2009 | 03:01 PM
  #5973
MassiveMods's Avatar
Originally Posted by backyardracer
hi peoples
I'm looking for a new eng. and just found this Item number: 220373384347on the bay. I cant find much info on it, is it a good eng? what does the "factory mod" part include? I have run SIRIO NOVARISSI V-SPEC ect in the past how will this compare? thanks in advance.
This is not a " factory modified engine " Go Factory do not modify engines. That is a gen 5 with a stock gen 5 crank. Id assume this guy is saying this to get sales but i can assure you it is not modified.
Buy from a local dealer and get some sort of back up service and warranty.
Cheers MM
MassiveMods is offline
Old 03-15-2009 | 03:43 PM
  #5974
Tabushi's Avatar
Originally Posted by losi_alaska
Look what I scored on today from a friend of mine, it cost me 1 thunder tiger .61 airplane motor and a castle phoenix 60a esc. Everything in the go box is still plasti wrapped, come on D8T I can't wait Here is a pic
Congrats man !!
And you got the new 0801 pipe series ... im waiting for mine !!, that stinger now its reinforced, very good !!
cya,
Tabushi is offline
Old 03-15-2009 | 04:09 PM
  #5975
Arushmen's Avatar
Default Re-fuling problem
Hi, I have a 5 port go engine on my hyper 9, I used to drive in Bogota, 2.600 mts over sea level.
My problem is that every time tha I am re-fuling (pit stop) my engine flame out. every time.
What can I do?
I have changed: Glow pug, for 6 to 4, I have made shorter presure line.
Arushmen is offline
Old 03-15-2009 | 04:53 PM
  #5976
22Racer's Avatar
Flameouts during pist stops are usually due to carb being too rich on the low speed. Is it the long lsn or short?
Rex
22Racer is offline
Old 03-15-2009 | 05:27 PM
  #5977
Arushmen's Avatar
Rex
Thanks Rex, but I am not able to understan you question?
what is lsn?
Arushmen is offline
Old 03-15-2009 | 05:31 PM
  #5978
Arushmen's Avatar
what is lsn?
If are you talking about "low speed nedle" How can I know if It is short o loger?
Thanks in advance
Arushmen is offline
Old 03-15-2009 | 05:50 PM
  #5979
Tabushi's Avatar
Arushmen,
I just answered your email sent to me today about this issue ... hope to help you,
cya !
Tabushi is offline
Old 03-15-2009 | 05:56 PM
  #5980
Arushmen's Avatar
Originally Posted by Tabushi
Arushmen,
cya !
Thanks Pato, I hope see you at Brazil.
Arushmen is offline
Old 03-15-2009 | 06:06 PM
  #5981
Default PTM Go Tech 5port
I ran my ProTwister modded - Go Tech 5port this Saturday at ReoRaceway in Indiana. I was top qualifier for the B-main, bumped to the A-main and finished 4th after a 20min main. I was most impressed with only 1 pit at the 10 minute mark. The Go Engine continues to be a reliable choice.
Thanks,
Brandon
Brandon Powell is offline
Old 03-15-2009 | 07:46 PM
  #5982
tagalong_74's Avatar
Originally Posted by tagalong_74
Ok guys have a question for ya. Just broke in my new Go 21.7port turbo. runs flawlessly. Now that I took the alluminum foil off, I'm wondering what temps are normal for that motor because this thing is spot on and with the body on after a full tank ran through im only getting to 190 deg F? That amazes me and was wondering if thats normal or not. Thanks again guys
Anyone Else!!!!!!!!!
tagalong_74 is offline
Old 03-15-2009 | 07:54 PM
  #5983
gravediggermaxx's Avatar
if anyone has a 5 or 7 port .21 for sell pm me thanks
gravediggermaxx is offline
Old 03-15-2009 | 08:49 PM
  #5984
22Racer's Avatar
Thanks in advance
The long low speed needle (lsn) will not pull all the way out of the orfice when you look in the carb while pulling the barrell of the carb open. (like going to wide open) The short lsn will pull out at around 1/2 throttle.
Rex
22Racer is offline
Old 03-16-2009 | 12:11 AM
  #5985
RETRO RC's Avatar
Congrats man !!
cya,
hey Pato why are you still waiting I've had mine well over 6 months now
The stinger isn't reinforced in the picture I believe it is just a reflection from the plastic shrink wrap
Adrian
RETRO RC is offline
