Xray NT1
#3872
Serpent springs, perfect fit. I run the blue or red serpent springs.
#3875
hey guys just put on the light weight upgrade xray first gear hub 335531 and I only ran it for no more than 5 mins and it started to free spinning in 1st gear is that a fault that cant be fixed or could something else that may have caused the problem, I have checked it and it is clean and free of any oil in the bearing and on the shaft?? do I need to have it replaced?any suggestions would be appreciated?
cheers
cheers
#3876
cheers
cheers
just clean the one way bearing with brake cleaner
and put one drop of xray one way bearing lube on it will be good a s new .
#3877
cheers
#3878
Heard the factory one don't last long. Sorry I got a used NT1 with a red gear hub and not sure who makes it so I am not sure how the factory one will hold up. All my friends are using the red one and I am still using the red one I got with the car and had around 50 runs on mine and it is holding up well.
ehirobo
ehirobo
cheers
cheers
#3879
some times fuel gets spilt on first gear and chases it to slip ..
when you took the first gear off was there oil on the shaft?
yes im using the ybslow battery tray and chassis weights
with my vmx 1300 lipo battery i put the extra 35 gram weights on the exhause side to balance up the car
i found the tray an weights settled the car down heaps you can also come in to the corners a little bit hotter
#3880
ehirobo
ehirobo
#3881
hi m8
#3882
are you talking about serpents new or old springs? cause the new serpent red is stiffer in the rear than light purple(looks pink), and blue front is even stiffer than light purple.. will recheck tonight but thats what I remember rating them as when I checked them a couple weeks ago.
#3883
Thanks man! Ask my friend last night and he told me they are 3 racing one. I am using light purple (look pink) up front and purple at the rear on high grip track we race on. For dusty parking lot I usually use purple up front with light purple or purple at the back.
#3884
Had the old one's laying around from my 710-720 days.
Btw, did anyone tried lowering the engine?. I think it's pretty easy to lower it by 1mm, because i'm currently running the serpent WC clutch with the small flywheel and it's pretty hard to get the starter wheel to grab the flywheel.
I would only like to know if you will run into issues with the stock flywheel i.e. hitting the ground.
#3885
O sorry forgot to mention, this is with the old springs, never used the new one's.
18Likes
