Go-Tech Engines Thread
#5687
#5688
They are still tight, so i would be on deck the start of the race before warming it up.
#5693
InfernoTb theGo pipes are made outof alumn. and alumn. is a metal that doesnot rust. probably the spotting you are seeing is some oil being burned onto the pipe from a fuel spillage. If you can't clean it off with some solvents and elbow grease then a lot of people will place the pipe in a crock pot filled with antifreeze and that seems to clean them up really well
#5695
I ran the JP-4 when I first got my 5PT, it was okay, runtimes were not that good though. Now i'm running the Go 0801 and it just blows away any other pipe I have tried, best performance on the 5PT, getting 10 min run times with the Go 6.5 restrictor and I'm even running a 14T clutch bell.
#5696
From: movin to the big time. on my way to the bay next week!
ok im new to the hole nitro engines thing. not really new to the whole tunning process of them, but when it comes to running different shims under the button, how do you know how many to run? i am running a p3 plug in a GO .21 3 port and right now it has 2 brass shims and the 1 aluminum shim and i am running 30% byrons fuel.
also i just got a new piston/sleeve/conrod for it as it is about to go out here soon. will i be ok breaking in these new parts with 30% fuel? i cant find 20% anywhere. no one around my parts sells anything less than 30%
thanks for the help
thanks for the help
#5700
I have read a lot of posts claiming that Go's run "Short" OS style plugs, i guess i dont understand, the plugs that Go manufacturers are standard or some would say Long plugs??? Why would they make a plug thats not right for there engine?
2Likes
