Like Tree18Likes
Xray NT1
Old 02-19-2009 | 05:43 PM
  #3781
RC MARKET's Avatar
Originally Posted by breez1090
you use em for both steering and throttle ? whats the model number for the ko low profile servo .....are they fast?
KO 2413 ICS
Futaba S9551
RC MARKET is offline
Old 02-19-2009 | 05:47 PM
  #3782
breez1090's Avatar
thanks
breez1090 is offline
Old 02-19-2009 | 06:31 PM
  #3783
rx7ttlm's Avatar
Originally Posted by rcfoolz
PDS 2413 and Futaba 9550 I just switched to the KO servo's
hey, are you running the helios? I am going to be running the 2367's with lipo with the 2.4 helios... hello fast & responsive.. hehe. and no lipo reg.
rx7ttlm is offline
Old 02-19-2009 | 08:09 PM
  #3784
rcfoolz's Avatar
Yes, running the EX-10, for now, I won't run a lipo Pack.....Takes the weight out of the car where it is most needed, only to have to put a heavy battery tray in its place..... I don't get it. I run a 1500 NimH pack and I only charge the car 1 time for each race day. If I had a lipo pack, I would be putting my receiver right next to it.
rcfoolz is offline
Old 02-20-2009 | 06:40 AM
  #3785
DS Motorsport's Avatar
I currently bought a Lipo which allows me to lower the tank by 4mm, and i can fit my transponder under the tank aswell.
When the car is completely finished i will weigh and balance the car and make a brass battery tray to get the car in legal weight.
DS Motorsport is offline
Old 02-20-2009 | 06:57 AM
  #3786
lil-bump's Avatar
I would not mount my transponder under the tank. You might have trouble picking up the scoring loop. I mount mine as forward as possible on the chassis in open site.
lil-bump is offline
Old 02-20-2009 | 10:29 AM
  #3787
I will make a 5mm hole exactly where the 'transmitter' of the transponder is, and it's about as far forward as when you mount it on the stock mounting place, only now it's central and at the lowest point of the car.
I'm not worried about any issues.
Old 02-20-2009 | 11:10 AM
  #3788
lil-bump's Avatar
I don't think the weight of your transponder will make much difference. I mount mine on the front bumper between the front body post. Whatever floats your boat.
Pass you soon...
lil-bump is offline
Old 02-20-2009 | 11:45 AM
  #3789
endy0430's Avatar
Default advice on radio's
hey guys what do you think of these 2 radio's for my nt1
http://www.amainhobbies.com/product_...rface%20Radios!
or
http://www.amainhobbies.com/product_...ducts_id/12290
endy0430 is offline
Old 02-20-2009 | 12:07 PM
  #3790
breez1090's Avatar
between the two of those i would say the futaba but i would recommend a futaba 3pk or a ko propo helios
Old 02-20-2009 | 12:15 PM
  #3791
Gerner's Avatar
Default Ko Propo EX-1 UR
Hey,
Get the EX-1 UR 2.4 ghz, all the functions essential for advanced adjustments, but a lot cheaper than EX10
Amain has it a very comp. price: http://www.amainhobbies.com/product_...ducts_id/27018
Gerner is offline
Old 02-21-2009 | 04:18 AM
  #3792
aussies1129's Avatar
how many guys are using the one piece engine mount (xray or 3R) with the four stiffner braces? what sort of characteristics did the car show make when they were added or removed?
cheers
aussies1129 is offline
Old 02-21-2009 | 08:29 AM
  #3793
RC MARKET's Avatar
Originally Posted by endy0430
4PK
Old 02-21-2009 | 10:53 PM
  #3794
bboy's Avatar
Pass you soon...
Would you mind sharing a picture of your wiring? I am worried the transponder wire might get caught with the moving parts...
bboy is offline
Old 02-21-2009 | 11:54 PM
  #3795
rx7ttlm's Avatar
well my reasoning isn't weight, its actually for the servo's. with the new ko servo's and rx you can run lipo direct. if you saw nigel's servos and response you would know why.. you turn the wheel and release it and as the steering wheel bounces, the servos jitter with it. my M11 and regular servos wouldnt pick up on the movement after it recentered. I just think its kinda cool i guess, not a LOT to be gained by it.
rx7ttlm is offline
