Like Tree7Likes
Old 05-12-2010, 11:36 AM   #5281
do any of you have used the 30g xray weight that sits between the engine and battery? the thing is that i'm hesitating in using it, because of overweight, or by moving the center weight of the car backwards, don't know, need advises, i will also try to balance the card by adding weight to the pipe side of the car, i will use the mini scales in for wheels. i also got the ti pivot balls i think they are made by atomic rc, supposing that the steel ones and these ti ones, are exactly same size, which ones will you use?
i'm trying to save some wieght by using the ti pivot balls and for then adding the balance weight and the 30g xray weight, but i'm affraid will be too much wieght.
mc_chofo is offline   Reply With Quote
Old 05-12-2010, 04:16 PM   #5282
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Originally Posted by tl2111 View Post
Not that much of the difference Alex.. main things is front bottom arm and rear link bridge which gives you bit more tuning ability.
Originally Posted by kickass View Post
Alex you cant go wrong, good choice, I run the 08 version and it still kicks ass. They last long time, you will n-joy.
Cheers
Alex.K
Thanks boy's . You guys are making my decision easier. lol i dont want to make a mistake again , if ya know what i mean .
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 05-12-2010, 05:59 PM   #5283
Trader Rating: 13 (93%+)
The front wheelbase is adjustable.
The top deck is a lot narrower which i believe creates more flex in the front, i am using a locker and i have a tonne of steering..when i ran the 08 i wasnt able to run a locker as it would understeer.
the belts are also 1mm wider to give you strength and reliability. Give ari a call at hei.com.au he has them in stock.
buy the kit and the blue soft springs front and rear, 2.2mm rear swaybar and if u like driving with a locker iw ould get that to xray make a super light front spool. otherwise run 150,000 weight front diff
call me if you have any other questions
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 05-12-2010, 07:00 PM   #5284
calling doesnt help me as you gave me a disconnected number
Old 05-12-2010, 10:33 PM   #5285
does anyone have any pics of the xray or 3racing graphite receiver bracket mounted on there car?
LiL_JaSoN is offline   Reply With Quote
Old 05-14-2010, 06:24 PM   #5286
bigshow4u's Avatar
FYI: Not sure if anyone else notices this or said somting but the large belt (the 390mm one) I believe is the same as a Losi JRX-S Pro but for around $5 less.
(I was trying to see if i could find belts that were less expensive for my JRX-S and thought u guys with the NT1's might save a little $$)
Losi part # is LOSA3302
3mm x 390mm belt, Grey in color.
If it's broke, I can fix it
If I can't fix it, It ain't broke
bigshow4u is offline   Reply With Quote
Old 05-16-2010, 10:39 PM   #5287
asw7576's Avatar
are u sure it can fit ?
Original nt1 belt is 396mm long ( 396mm divide by 3mm pitch = 132 teeth )
Losi belt is 390mm = 130 teeth
2 teeth difference is quite a lot. ..... u need to install it to make sure the belt won't over strecth.
The width is also important too.
Too narrow, the belt will skip or ruin easily.
Old 05-16-2010, 11:14 PM   #5288
PDX-Spike's Avatar
At 132 teeth at the tightest setting, my NT1 belt is a little looser than I would like. Subtract two teeth and I would probably like it alot better. I'll probably get one and see if it will work.
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Old 05-17-2010, 01:49 AM   #5289
asw7576's Avatar
OK, I take note on that. 130 teeth can fit even better.
Is the width same ?
Old 05-17-2010, 07:17 AM   #5290
bigshow4u's Avatar
Losi says they are 3mm wide but i measured mine and its 3.5 maybe 4mm.
If someone does try this and it does NOT work, I'll buy the belt from ya since i run a JRX-S.
Old 05-18-2010, 02:10 AM   #5291
does the spektrum SR3000 or SR3001 fit in the xray receiver box?
Old 05-18-2010, 05:43 AM   #5292
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Yes
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 05-19-2010, 06:50 PM   #5293
hi i saw a post by musti72 on another post saying that the nt1 multiflex engine mount doesn't really work that well and instead most racers have replaced it with the original one is it real? i have the multiflex one installed on my nt1 but i didn't test the stock one, what would be a better option regular one, or the multiflex?
Old 05-19-2010, 07:03 PM   #5294
casino57's Avatar
I'd try the stock engine mount and the 3mm chassis. We like running a little flex in the chassis.
Mike Garcia - RCAmerica - XRay T3
Trinity - JDR - Hudy - KoPropo America
Laser Products - Tekin
Leisure Hours Raceway & Hobby Shop
casino57 is offline   Reply With Quote
Old 05-19-2010, 08:29 PM   #5295
but which one is better, the mf without the graphite arms? or the standard one?
