Xray NT1
#6781
#6787
#6789
Help!
My buddy is looking for a Rubber tire setup info for Nitro GT Open.
NITRO TRANS AM STOCK RULES
1. ANY 4WD NITRO CHASSIS KIT OR RTR (must retail for under $400.00)
2. HPI VINTAGE TA BODIES ONLY. The bodies must be painted to depicted full out race cars. (other company bodies will be added to the list shortly)
3.HPI VINTAGE WHEELS AND TIRES ONLY (stock insert must be used)
4. RTR CARS MUST USE THE FACTORY INSTALLED ENGINE (if you happen to blow your engine you must replace it with the same type of engine or you may replace it with a .12 engine (must retail for under $160.00)
Addendum's to come shorty.
NITRO TRANS AM OPEN
1. Any 4WD Nitro Chassis
2. Any .12 Engine
3. Only HPI Racing Vintage Wheels & Tires
4. Only Outlaw Trans Am Vintage Body
STOCK NITRO GT
2. Any 200mm HPI RACING Two Door GT Type Bodies. The bodies must be painted to depicted full out race cars. (other company bodies will be added shortly)
3. Any 26mm Rubber Tire may be used. Must also use racing spoke wheels, NO DISH WHEELS PLEASE.
Nitro GT Open Rules
2. Any .12 Engine
4. Only HPI RACING 200mm Two Door GT Type Bodies. The bodies must be painted to depicted full out race cars. (other company bodies will be added shortly)
Saturdays at Cal Raceway Starting in June.
REAL RC RACERS & CAL RACEWAY ARE PROUD TO BRING YOU
1/10 SCALE NITRO TRANS AM AND NITRO GT RACING
NITRO TRANS AM OPEN
2. Any .12 Engine
STOCK NITRO GT
Nitro GT Open Rules
2. Any .12 Engine
#6791
http://www.amainhobbies.com/product_...ll-Link-Pliers
Will this tool work to remove shocks and steering links, etc on the NT1?
#6792
yes
#6793
hold up so u gain steering by running heavier oil in your front diff? I thought that would/should make it push! but I race with a guy who runs the 747, car has awsome steering, turns on a dime n i swear hes running a million weight or more up front!!!! on Dj apalaros setup for the cap co2 he says i run 200k up front but i like a car that pushes a little, if u want more turn in drop down on the oil!!! so even some pros beleive that heavier oil will induce a push........im confused
#6795
