Go-Tech Engines Thread
#5401
So meaning soft do the vp shoes wear out really fast? I know in buggy the mugens last a long time with 1.0 springs. they just cost a ton! .9 springs will tame the beast huh? I will have to try that combo.
steve
steve
#5403
Rocket42 - I will try the 0.9 springs next meeting. I always thought that they would make the clutch too early and bog out of the corners, but I guess the 5 Port has the bottom end to make up for this.
#5405
You probably have a carb with the long LSN. These tune a little different to most carbs out there. Set the HSN at .5 of a turn in from flush and the LSN at 2.5 turns in from flush. This should be pretty close. Don't touch the HSN again, just tune in from here with the LSN. If you go any leaner on the HSN you will get lean bog at the top end or when the tank gets down. Set like this the motor will perform flawlessly, but if you prefer a more "normal" tune on your motor, then grind down the LSN as Rex suggests. It works very well, and allows you to tune with the HSN as per any other motor. You will end up with HSN at about 2.5 - 3 turns in from flush and the LSN about the same as before, maybe a little leaner - around 2.5 - 3.5 turns in from flush (depending on pipe, fuel etc). Let us know how you get on
Do I just cut it with a Dremel cutoff wheel and then use a sanding disk or drum to round it ?
Also does anyone know if any other manufacturer LSN will fit on my GO 5PT carb ?
I used the method described obove to tune it and so far so good I haven't really tested it on the track yet, but I still felt more comfortable when I used my old sirio carb & reguler short LSN for tuning.
My setting is this so far :
HSN= .250 (1/4) turn in from flush
LSN= 1.75 (1 3/4) turn in from flush
at 2.5 in from flush on the LSN it would bog for an instance when I hit the throttle, at 1.75 feels good.
#5406
You just have to shorten it down to 2.425 or within .025 or so. I personally just hit it on a belt sander then round the end. (bullnose) A Rb/ novarossi lsn needle will fit, the carb is an exact copy of the Nova carb.
Rex
Rex
#5407
hey guys,
im getting a smoking deal on a Ofna Lx buggy with a gotech .21
my question to you guys is,
is there a turbo button for the sport 3port motor?
this guy is claiming that the motor in the buggy is a turbo plug but after searching the only motor i can find that it matches is the sport motor(blue head) and i didnt see a turbo button for it anywhere..this guy got the motor in a trade and doesnt know much about it so maybe just a simple mistake,
thanks
thanks
#5408
hey guys,
thanks
thanks
#5409
here is a pic of the car with the motor. look identical to the 3p sport motor, i was just curios if they had made a turbo button that maybe the p.o. swapped in, the guy im buying it from bought out a guys whole lot of stuff and this buggy was in it.
since im new to nitro do the turbo plugs look different then standard, that why i can just pull it and look for myself when the car gets here
#5410
http://www.amainhobbies.com/product_...ducts_id/10573
in the description says for the 5 Port but it's for all race and sport .21 Go engines.
#5412
you say shorten it down to 2.425 is that total size of the needle or what ?
I don't quite understand( I used to race electric only).
Also I assume that is milimeters ?
I will also be looking for a LSN from RB/nova thanks for the advice !
#5413
.The original needle has a total length of 1.6 inches. Grind this down to a total length of 1.42 inches and round off the end just like Rex described. If you prefer mm then make the total length of the needle 36 mm.
This will allow you to tune the motor like any other, using the HSN, then fine tuning the LSN.
The GO motors are fitted with the long LSN's to provide a nice smooth power band. The LSN stays in the spray bar right up to full throttle, which is why they require a richer HSN than normal to let enough fuel through. If you tune them as described on page 131 / 132 of this thread you will have no problems - they run awesome. It's just a slightly different tuning concept thats all. The short needle works fine also. It comes out of the spray bar somewhere between 3/4 and full throttle, so you can run a leaner HSN like other motors. Whatever needle type you decide, your motor will perform nicely
#5414
The turbo head button combustion chamber has a more rounded (hemispherical), shape and the turbo plug sits flush in this chamber giving a very smooth rounded area for combustion to take place, allowing better, faster flame propgation during ignition. This is why turbo buttons and plugs make a little more power and idle better.
With the standard head button the base of the plug slightly protrudes into the combustion chamber, hence not giving the same performance enhancing characteristics as the turbo combination.
If you want the best performance out of your nitro motor you really need to run a turbo head if it is available.
2Likes
