Like Tree18Likes
Xray NT1
Old 06-12-2008 | 04:57 AM
  #3121
pro shop futaba in japan sells them
mrgsr is offline
Old 06-12-2008 | 06:01 AM
  #3122
Any other online shop that is English?
Ramiel is offline
Old 06-12-2008 | 06:34 AM
  #3123
Originally Posted by Ramiel
Where i can get those active racing lightweight heatsink online?
you can also get them from www.rcmarket.co.hk i think that is the website. just google rc market and the website should come up. there are three colours blue red and gun metal grey.
TomB is offline
Old 06-12-2008 | 08:55 AM
  #3124
mtveten's Avatar
If you really want to get down to the ROAR requirement all you need to do is change to either a lipo or AAA receiver pack. My car with full size electronics is is only 3 grams over with no other weight saving mods & 54/55mm foams. Remember your required to make weight with a dry tank AFTER the run so your weight with race ready foams needs to be higher.
Mark
mtveten is offline
Old 06-12-2008 | 09:18 AM
  #3125
It's http://rcmarket.com.hk and I found it.
Thank you very much!
Ramiel is offline
Old 06-13-2008 | 06:25 AM
  #3126
just remember to re check your engine temp and tune with the new heatsink, as it may affect the tune slightly either make it run a bit cooler or hotter, depends on the place you race at. also there is less amterial so it may run a bit hotter, who knows, just double check though.
TomB is offline
Old 06-13-2008 | 06:32 AM
  #3127
TomB is offline
Old 06-15-2008 | 04:17 AM
  #3128
bboy's Avatar
I have trouble balancing my rear stablizer. When I lift the left arm, the right arm moves instantly but when I lift the right arm, the left arm doesn't move at all. I detached the suspension and droop is set the same.
Any one knows how can I fix this problem? I tried varing the lenght of the stablizer rods (the ones that connects the arm to the stablizer bar).
bboy is offline
Old 06-15-2008 | 07:40 AM
  #3129
British Menace's Avatar
Hi bboy,
First thing to check.
Take your shocks off again, and take your stabilizer link rods off too.
Now check that there is no binding in your A arm movememnt. Make sure both drop under their own wieght and that both are the same.
Now re-check/ adjust your droop screws.
Check your stabilizer moves nice and smooth while not connected. If ok. Re-attach to one A arm and check the movement by moveing the arm up and down. Check the length of the stabilizer connecting rod.
Now check how your other A arm lines up with the stabilizer bar fitting and adjust as necessery to get the same droop both sides.
Fit the bar to the other A arm and remove it from the other side. Is the movement still as smooth? The same?
Carry on from there checking the droop with suspension off but with stabilizer on and adjust rods to equalize.
Ensure your shocks are long enough and are the same length before attaching. Make sure the connections on the shocks. At top and bottom on the A arm's are not too stiff and binding the A arm movememnt.
You should find your problem working through it like this.
Regards,
British Menace
British Menace is offline
Old 06-15-2008 | 10:33 PM
  #3130
Goingfast's Avatar
Who got the best deal on line( NT1 parts)?Thanks
Goingfast is offline
Old 06-15-2008 | 11:07 PM
  #3131
nexusracing.net are the cheapest by far and have evrything in stock
and great customer service
mrgsr is offline
Old 06-15-2008 | 11:09 PM
  #3132
simple get some camber link turnbuckles and use these instead of the very difficult to adjust and inacurate threaded shafts. this way you can give the tunrbuckle a small twist with the wrench and get them lifting up exactly the same time.
it is not lifting at the same time due to one side having a longer turnbuckle than the other.
TomB is offline
Old 06-16-2008 | 11:22 AM
  #3133
teamgp's Avatar
Also check to make sure that the set screws for the anti-roll bar are snug, but not too tight. Disconnect the rod ends and tighten each set screw individually until they are snug, but allowing the bar to move up and down freely. Make sure to check the set screws frequently, as they back out quite often. When I first put on a bar, I use a dab of CA blue on the set screw to keep it from backing out after I tighten it down correctly.
teamgp is offline
  #3134
Goingfast's Avatar
I'll check is out ...Thanks
Old 06-16-2008 | 12:26 PM
  #3135
RC MARKET's Avatar
Sorry Active no stock !
i'll check again !
RC MARKET is offline
