Go-Tech Engines Thread
#2896
Thanks for the help guys. Is the black insert that the screw goes into two separate pieces? If so, I will try to screw the screw into the opposite side as 2cool suggests and then pull out the inserts. After I get it out, what do I need to do to get it to lock down properly again after reassembly? I can barely see the top of the oring, is it possible that it is still slightly up as Vigilante212 suggests? I need to fix this issue for a race this weekend.
Thanks again.
Thanks again.
The brown coloured O Ring in the bottom of the carb insert of the crankcase is recessed into the crankcase. When you install the carb you need to push the carb down firmly onto this O Ring and tighten the pinch bolt with the carb held firmly in this position in order to get a good seal.
I have just ground the pinch bolt on my spare 5 port engine which had slight play in the carb and it is tight as now. You may want to check the brown coloured lower O Ring and replace it. You will find when the carb moves from side to side it chews this O Ring up a bit. Hope this helps
#2897
#2901
Thanks again.
Thanks again.
#2902
If anyone is interested in a new Go 2047, I have one for sale.
Email: [email protected] for pricing.
#2903
Does anyone know where you can get the best price on the GO engines?
I am looking at maybe the 25 6 port or the 21 5 port and a pipe. I noticed on Ebay there was a combo package available. Was that a one time promotional deal? Do they even still do that, I haven't noticed it on any of the reputable sites? There is no model number given for the pipe either, but it looks to be packaged from GO.
Thanks!
Thanks!
#2904
grizz, it is the shizzle
i would recomend this pipe for the 3 5 and 7 ports and the .25, it has a long header with basicly a 086 pipe, i put the NR 086 and the GO 0801 side by side and they are very close, i ran my 0801 on my stock 7 port and it was killer, really wakes up the bottom on the 7 port and top end was outstanding considering the amount of fuel i have on the engine, runtimes are over 8 min at this point.
#2905
Thanks!
Thanks!
#2906
Hey Brian do you have any of the 0801 pipes. Got 6 tanks on the 25 and right now it seems like it is gonna be a powerhouse, probably gonna try to go up a tooth on the c-bell. Also any word on the turbo button for it--just want all my motors to be turbo so i only have to carry one type of plugs around.
#2907
The 5 port has the most low end torque, followed by the 7 port. The 3 port R from what I hear is very smooth on the bottom end (depending on pipe and clutch set up of course). Most people running truggy go with the 5 port and 086 pipe. This is plenty of power for any truggy. If you want a smoother power band down low in the truggy go for the 7 port with 053. Even though it's smoother on the bottom end it still has heaps of grunt for a truggy.
3 port R is better suited to buggy, and the 7 port is also a sweet buggy motor if running a medium to tight track.
#2908
I don't have the 3 port but I do have the 5 and 7 port 21. The 5 port has a lot of torque but this can be tamed with clutch set-up. I initially had aluminum shoes with 1.1 springs but I felt the engine had too much low end punch. I now have Mugen aluminum shoes with 1.0 springs which tamed the torque down some. I might try 0.9 springs to help softened the low end a little more.
#2909
2Likes
Reports on the 0801 pipe please
