Like Tree2Likes
Go-Tech Engines Thread
Old 01-02-2008 | 08:03 PM
  #1111
petevette's Avatar
Quick question, are the settings the engines come with good for start up? i know that I have to use the top to regulate the temp once it starts, but should I start it with the factory settings?
petevette is offline
Old 01-02-2008 | 08:13 PM
  #1112
Rocket42's Avatar
Yeah the factory settings are pretty close.
Rocket42 is offline
Old 01-02-2008 | 08:18 PM
  #1113
petevette's Avatar
thanks, appreciate it.
Old 01-02-2008 | 09:32 PM
  #1114
Originally Posted by Jason Halvorson
the Go .28 is on par with or better then all the engines you have mentioned...
im now running a prototype turbo button in my .28, and wow that thing will rock...its almost to fast...
I think my standard plug .28 is almost too fast...haha.
revo_race is offline
Old 01-03-2008 | 09:01 AM
  #1115
MadRussian's Avatar
Really? Whoa!! Do they make a 5-7 port 28 with pull start? All I have seen are started box type
MadRussian is offline
Old 01-03-2008 | 09:40 AM
  #1116
dgraham225's Avatar
i just got my go tech 5 port in finally, i thought they i read they come with two plugs already? did i misread that somewhere, bc it didnt come with any at all? and does the turbo button always come seperate in the box? now i gotta order some glow plugs i guess, LOL! that sucks!
dgraham225 is offline
Old 01-03-2008 | 09:45 AM
  #1117
free2day77's Avatar
the turbo engines do not come with plugs as GO does not make a turbo plug.
free2day77 is offline
Old 01-03-2008 | 09:46 AM
  #1118
salteen's Avatar
what he said^
the buttons were installed when I received both of my motors...that is kind of strange that it was removed.
salteen is offline
Old 01-03-2008 | 10:30 AM
  #1119
will g's Avatar
how ports on that 28 you guys talking about ?
will g is offline
Old 01-03-2008 | 10:38 AM
  #1120
free2day77's Avatar
GO makes a 3port and 6port 28's
Old 01-03-2008 | 11:20 AM
  #1121
will g's Avatar
cool thanks for info i was just trying to see what engine was being talked about in couple posts ago thnx will g
will g is offline
Old 01-03-2008 | 11:34 AM
  #1122
free2day77's Avatar
my bad, read your post too quickly, not sure which they were talking about
Old 01-03-2008 | 11:48 AM
  #1123
Maximo's Avatar
the Go 28 6 port is closer to a MT 28 then a Ninja 28...the Ninja is a short stroke long rod 28...the Go is a long stroke short rod 28........... the Ninja is really a bored out .21...the GO is a typical long stroke 28............................ Guys do not underestimate the Picco/Jammin engines.......I run both Go and Picco engines, and to dismiss the Picco's like your doing is not very accurate on how these motors run.........
THere is no way the Go 28 6 port is going to have the powerband and legs of a NInja 28, the internal geometry is not there ... the GO 28 is identical pretty much to the older MT style 28's, definitely not a new gen 28 sorry to say..... I will gladly have one dynoed if you want to see its powercurve next to a Ninja 28....
I am not knocking the GO 28 either, but the Ninja 28 is an amazing 28 with a killer top end no other 28 I have seen even comes close to........i mean the Ninja is built to rev....
as I say I am not knocking Go engines, as I myself have run Go engines and love them.. But the Ninja 28 is a pretty special .28 with unique internal geometry which allows it to rev higher then a typical 28 design.... I can definitely see the GO 28 6 port being a good matchup to a Jammin 28 as far as powerband and RPM, as they share the same bore/stroke and nearly identical timing profiles...The Ninja on the other hand is quite a bit different then the Jammin or Go..
Maximo is offline
Old 01-03-2008 | 12:31 PM
  #1124
will g's Avatar
cooooooooooool im looking at buying a 28 3 port or another 5 port just getting ideas thnx guys
will g is offline
Old 01-03-2008 | 04:43 PM
  #1125
mugenb46's Avatar
russ, the anticipation is killing me
mugenb46 is offline
