Like Tree2Likes
Go-Tech Engines Thread
Old 01-01-2008 | 03:28 PM
  #1081
3 Port Go Tech - -
Guys,
I ran the Go 3 Port this past Sat. at the TN State Championship. The engine is a great "indoor, tight track" 1/8th motor at any level, or a stout budget motor for the begginner at any track. I had a 10th place overall finish, with the motor running impressively all night without having to touch the needles.
Set up -
Go Tech Sport 3 port
Turbo Button
Race Carb (Set up is close to the new production Race 3 port)
8 mm Restrictor
OD 77T plug
1.1 Springs / Purple Ofna Clutches
Dynamite 053 Pipe
Brandon Powell is offline
Old 01-01-2008 | 03:35 PM
  #1082
kamlooper's Avatar
Thanks Brandon. The race carb, you mean a carb off a 5 or 7 port? Std. carb not too good?
kamlooper is offline
Old 01-01-2008 | 04:09 PM
  #1083
kamlooper - Yes, I ran the composite carb. off of the 5 or 7 race engine. I have not heard of any trouble with the aluminum. I was wanting to get comfortable with the new 3 port we have coming and it was a very similar engine.
Restrictor - 8 mm is what I ran. After a 5 min qaulifier I came in with a little under 1/2 tank in my buggy. I was good for 8 to 9 min easy. I also feel you can make the 10 min mark with a 7mm or 6mm.
Old 01-01-2008 | 04:38 PM
  #1084
mugenb46's Avatar
brandon, i will start getting into your 7 port wed, it will be a direct copy of my motor.
mugenb46 is offline
Old 01-01-2008 | 04:52 PM
  #1085
dgraham225's Avatar
oh ok, well thats cool, i guess thats really kinda common sense, lol! i cant wait to get mine in and running!
dgraham225 is offline
Old 01-01-2008 | 04:57 PM
  #1086
Thanks.
Rocket42, We also had a 2 Go- 5ports, and Brian's 7 port at the race. All ran good. Brian's 7 port was strong.
Old 01-01-2008 | 05:09 PM
  #1087
Jason Halvorson's Avatar
Originally Posted by revo_race
That's what I'm hoping for. I'm only seeing about 6 minutes out of my .28 right now. The carb inserts are on their way so I'll get to test those out and also I'm going to play with different clutch bells and spur gears. When the .28 dies I was hoping to replace it with a .25 and be able to get roughly 9 or 10 minutes out of it. If I can see 8 minute tanks with the .28 on my track I'd be really happy.
ive been getting 8 minutes out of my .28...im running the Go 2047 pipe, OD97T plug, 7mm carb insert, 13T clutch bell, 1.0 springs and mugen soft Al clutch shoes...
Jason Halvorson is offline
Old 01-01-2008 | 05:25 PM
  #1088
I haven't actually tried timing my run times yet but I know for my first race I tried pitting every 6 minutes or so. I've run around the track with a fellow 8T owner that has a vspec and we went for what seemed like a lot longer than 6 minutes before filling up. I'll get a stop watch out once I get the carb inserts and see how long I can go. 8 minutes or more would be awesome, can't complain about that.
revo_race is offline
Old 01-01-2008 | 07:25 PM
  #1089
VoodooDaddy's Avatar
Ill putt my 5port up aginst any thing .......................Thats one mean motor
VoodooDaddy is offline
Old 01-01-2008 | 07:29 PM
  #1090
skeller's Avatar
You had it strollin the other night....that's for sure.
skeller is offline
Old 01-02-2008 | 04:15 PM
  #1091
Does this look like a go tech?
pooldoc is offline
Old 01-02-2008 | 04:21 PM
  #1092
the block does...
Old 01-02-2008 | 04:34 PM
  #1093
Carb looks the same too, saw this posted on another forum as the new OCM engine and pipe.
pooldoc is offline
Old 01-02-2008 | 04:36 PM
  #1094
free2day77's Avatar
whats the 'best' pipe for the 3 port?
free2day77 is offline
Old 01-02-2008 | 04:52 PM
  #1095
sport or race???
if sport the 086 or 2047...
if race im not sure, but im betting the 086 is gonna be the best pipe and or once again the 2047...
the Go 2047 is the pipe that im finding works great with everyone of the Go engines i have tested it on...
