Like Tree2Likes
Go-Tech Engines Thread
Old 12-20-2007 | 09:01 PM
  #931
casterdriver's Avatar
Thought you guys might get a kick out of this.......the vid really isnt of my truck(the white one) but its in there enough to be worthy of watching I think , I was only driving my truck for the last 30 seconds of the first vid and then all the rest of the other 2, ..... Caster K8T Team truck, PTM 5-Port Turbo, Werks 053, OD 97T, Werks 30%..... super consistant 220-230 on a 65 degree day, mugen 1.0 springs and 3 shoe clutch(could use 1.1's in certain spots).......my buds yellow X-Ray has a heavily and I mean HEAVILY modded Picco P7R EVO2, its no slouch even with carb problems....but it was having to run 280-290 to do what you see here.......
http://hdrcvideos.com/video/12162007/practice_cut_1.wmv
http://hdrcvideos.com/video/12162007/practice_cut_2.wmv
http://hdrcvideos.com/video/12162007/practice_cut_3.wmv
casterdriver is offline
Old 12-21-2007 | 06:16 AM
  #932
will g's Avatar
hey jason got ? for ya about 5 port go motor im running ive got almost 6 gallons thru it and have replaced the front bearing with a tko ceramic already at 4 1/2 gallons when should i be looking to change the rear bearing and what about the connecting rod. thnx will g
any one going to nitro challege or silver states
will g is offline
Old 12-21-2007 | 07:12 AM
  #933
hansarvin's Avatar
Originally Posted by satoch
You can run the 5 port with an 053 pipe, 1.0 or 1.1 springs, and aluminum shoes at LH. Forget the Inside Jobs. Switch 2.0's or Losi Pink Tapers only.
Talking bout RCR bruce, you remember what it was like the last time you were there right after the rain... But for LH yea Switches.
hansarvin is offline
Old 12-21-2007 | 07:49 AM
  #934
You may want to try those new Sportwerks Hot Laps Qualifiers at RCR. They have a great tread and they are really cheap. I have a set I can't wait to use there.
satoch is offline
Old 12-21-2007 | 11:09 AM
  #935
Jason Halvorson's Avatar
will g this is MHO...i would remove the rear bearing and give it a good inspection, if the bearing is still nice and smooth, showing no to very little wear and has no graineness what so ever...i would continue to run the bearing for 1.5 ro 2 more gallons and then repeat inspection...as for the connecting rod...i would replace it somewhere around the 3 to 4 gallon mark...
Jason Halvorson is offline
Old 12-21-2007 | 11:14 AM
  #936
will g's Avatar
thanx jason i will check engine tonight and see how the bearing looks but looked good 1.5 gallons ago and im very happy with motor and am looking for another one now for the buggy. ive been swapping out the 5 port in truggy and buggy and it has plenty of GO power thnx will g
will g is offline
Old 12-21-2007 | 11:20 AM
  #937
will g yea the 5port is a great engine...however you may want to wait for just a bit to see how the 3port race engine works out, you may want this engine for your buggy...
Old 12-21-2007 | 11:38 AM
  #938
will g's Avatar
IVE ALREADY EMAILED RUSSELL ABOUT IT I MAY WAIT IM HOPING WE CAN GET IT OUT BEFORE FEB THNX WILL G
will g is offline
Old 12-22-2007 | 07:42 AM
  #939
kenshinmd's Avatar
Hey guys I have a .26 mill that I use for my truggy, but I have yet to put a gallon into it since I only use it during races. i've already change the conrod after break in. My question is are there any issues with the engine that I should keep watch? Presently i'm using a jp2 pipe but it lacks the top end, is the 2047 also suited for a .28?
kenshinmd is offline
Old 12-22-2007 | 08:30 AM
  #940
Steebo's Avatar
crappy foams. If sportwerks stepped up the foams that they put in there i think these would work really good.
Steebo is offline
Old 12-22-2007 | 08:53 AM
  #941
hansarvin's Avatar
Is this at Redline R/C in Marion??? It looked like it, just wondering. My Aunt lives there and I saw it on the way back, and we're coming down again this summer so we're going to stop by.
Old 12-22-2007 | 09:11 AM
  #942
Maximo's Avatar
Hey thats my Picco 21 beating up that Go-Tech!!! poor little guy was having some carby problems that day.....it seems the aluminum end cap on the carb separated from the main carb body, very similar to the problems with the Go-tech carbs......hopefully a little JB weld fixxes the problem...power should come up and temps should come down
Maximo is offline
Old 12-22-2007 | 09:28 AM
  #943
Rocket42's Avatar
kenshinmd the 2047 has bee working very good on the Go .25 and .28 it will improve top end over the jp-2.
Rocket42 is offline
Old 12-22-2007 | 06:04 PM
  #944
Toys-4-Big Boys, San Antonio, Texas... NE Side of town.
Old 12-22-2007 | 07:38 PM
  #945
hansarvin's Avatar
o ok haha that's a little farther away (I'm in Central Illinois)
