Go-Tech Engines Thread
#946
jason, when will the 3 port be available? im gonna be in need for a new motor in about 2 months, i was thinking about giving them a try, they sound hard to beat for the price? but i want to see how the 3 port stands up to the other two!
#947
I'm starting to like my .28 in my 8T more and more every time I use it. I'm using a Dynamite 086 pipe and have about a gallon of fuel through it now. It screams! I still have the extra head shim from the break in period in it right now. I ran with a vspec powered 8T today and our run times were very similar. For my first race I was fueling every 6 minutes or so but I think it might be able to go at least 7 minutes on a tank. I'm going to try a 7mm carb insert for it pretty soon and see how that helps, also I'm going to go from a 13t clutch bell to a 14t. Once I do all that I'll start timing my fuel tanks to see where I'm at.
#949
just thought that i would bring this up:
last time i ran my 7pt turbo, i was using the os p3 plug as prescribed by everyone on here and on the grid.
my motor last ran on labor day weekend, since then, the motor has sat. a buddy of mine needed to borrow a motor to get a good setup for his k car, he installed the motor, went to the track and it wouldn't start, (remind you that this motor was sitting on my shelf since the 1st weekend of september.) i did use after run oil before storing the motor.i told him to buy a p3 plug, he buys the plug, and the motor still wouldn't start. he calls me to tell me that a very knowledgeable nitro tuner told him that the taper on the button is different then an os turbo button, so the p3 plug wouldn't work. the guy gets him a different turbo plug(i think he said he got an oddonell plug) and the motor fired right up,no issues at all, tuned a little bit for the cold weather and was running awesome.
has things changed for me since sept.
please reply back with any comments
#952
for me it ran awesome. i'm not concerned about it as long as the thing runs. the motor has not once given me a problem, i just thought it sounded it weird to me, i don't have the motor so gettn a picture right now is out the ?
i know that a 1-11 npt thd(american) is different than a 1-11 bspt thd(europe, asia) so i wasn't sure if the the os plug is a different thd than the go turbo id thd's
#954
#955
#957
If I don't notice any significant change in performance or the tune before the gallon is completely gone, I'll go ahead and take it out after my gallon jug is empty. I only have probably four tanks of fuel left in the gallon though so it won't be long...The only thing worrying me right now is that my starter box has a hard enough time trying to start it as-is!
#958
#960
I think it may just be the byron's fuel my 7port has almost 4 gallons and it is still really tight my lipo powered mugen box was having trouble turning it over i wore a nasty groove in the wheel and had to replace it at the 2 gal mark
i was frustrated because the break in was taking so long, now it turn over but still with alot of effort. I was not pleased with the motor at first but now im loving it. Like the high dollar novarossi /Rb motors they take a while to break in
Russell or jason I have a ? would the older 3 needle carb hurt the mid range im running the 053 and low end is awsome same with topend but i still have a dead spot/lag in the midrange? would i benifit from the newer 2 needle carb?
2Likes
