Go-Tech Engines Thread
#796
Hmm - you have left me wondering guys.
Jason, I have a 5 Port (soon to be turbo head) in my buggy with a Dynamite 086 fitted. Allowing for the cost factor, do you think it would be worth while changing this to the new GO 2047, or is the performance so close it wouldn't matter ?
Thanks Mark, I will have to think about which pipe to get. Truggy on pretty tight lay outs with Turbo 5 Port - I am leaning LRP way. I have seen two different pics of the LRP 2063 pipe so perhaps you could confirm for me - does it have a re-inforced stinger ?
Sorry to be buggin you guys with so many questions, but I want to get the best set up possible first time around for both my rides. Plus I don't think the other half will put up with too much more expenditure on my "toys"
Thanks - grizz
PS: Retro - good luck at the nationals mate. I hope to get down to Hamilton for a look at the finals on Sunday if everything goes to plan.
Thanks - grizz
you'll be able to find me pretty easy I'm sure
Adrian
#798
hey rltanner i would go with the 5 port i run the 5 port standard plug in my truggy and it still very fast plenty of power im also running a dynamite 053 with makes it smoother thru the middle thnx will g
you going to make to nitro pit to run with us next week ?
#802
#804
#806
#809
I doubt the 5 and 7 ports are different than the 3 ports in regards to squish.
I'm running a turbo button on both my 5 port and my sport 3 port. After about a gallon of break-in using the Adam Drake method, and an additional race weekend, on the 3 port I've gone from the stock .30mm to .21mm. I do use a cooler plug than the OS P3 however. It's the Merlin Glow Plugs EHD #5 turbo. I've got no problems and I'm getting longer run time now.
#810
How come the carbs neck is plastic with a metal sleeve over it........This is the reason why my carb is able to turn when the pinch bolt is pinched tight.....The metal sleeve stay`s in place and the carb neck turns inside.....Is there another carb that will fit the go or do I need just to buy another GO carb
2Likes
