Like Tree2Likes
Go-Tech Engines Thread
Old 08-16-2009 | 03:33 PM
  #8296
Originally Posted by RCHavoc
The new website should be up before long. GX Motors should be in soon as well. If you guys need anything, you can always email me. I have contact with Russell on a daily basis. Thanks!
[email protected]
this is very true Russel is stay pretty busy, and working hard on the new web site, and if you need it he gets it asap if your in the Texas area and cant reach him reach me
@ thecreditsnipergmail.com
leapinglizard is offline
Old 08-16-2009 | 03:45 PM
  #8297
I have finally got some racing weather fellas, I been out there putting my thing down LOL. The Powerhouse 3 port race is just amazing. It dont stop and I could squeeze 10 mins out of it to, I like that alot. I am still here if needed PM me if anything. Dont nobody get mad but I have been attempting to build a E-buggy LOL. The e-class has been growing around here and they look like fun also. But if I EVER go somewhere and they are running the buggies all together sorry E-buggy LOL. It will have GO stickers on it anyway.
malik is offline
Old 08-16-2009 | 04:19 PM
  #8298
RCHavoc's Avatar
Im running the 3 Port Sport with Turbo Head Button, Race carb and race cooling head. The 3 Port Race has a smoother powerband where the sport is a little more punchy...
RCHavoc is offline
Old 08-16-2009 | 04:59 PM
  #8299
grizz1's Avatar
Originally Posted by mattwoodcraft
i think you will find that he was saying to put the extra shim under the head button
Adding shims under the head button would only effect the compression ratio.
I think 22Racer was refering to a shim under the sleeve itself, which has an effect on the timing and hence the power band. Sounds like a great concept for guys with stock 5 ports in their buggies that don't want the expense of getting a full mod done to tame the bottom and extend the top.
Maybe Rex could explain further ??
grizz1 is offline
Old 08-16-2009 | 07:59 PM
  #8300
InfiniteMotors's Avatar
Originally Posted by OzzyNitroJunky
Hi guys, just hoping I could get some advice on my new engine pipe combo that will be going into my RC8 soon. Now I know asking what gear people think is the best can be biased but I'm now stuck in a bit of a jam as of which way to lean. Like I said Ivé got an RC8FT that I am currently running a V spec with 2060 pipe. I'm looking for a new mill for the rest of this season and next year as the V spec is starting to feel a bit tired. I was thinking about getting a WS73 but for the price and the amount of racing I do and not to forget that I'll never realy be a threat to the fast guys, I just one a bang for your buck engine that will still deliver the goods as my skills improve. So I've been looking at the Go engines but now can't decide on what one to get. I will be racing on a high bite blue groove surface that is fairly flowing, so would the 3, 5 or 7 port suit me better.
From what I've learned about the Go's, it seems like the 3,5, or 7 could work in almost any situation. I started with a 5 and ran it hot. It had more top end than any of the guys I raced down the straight, but when I got into the technical sections it performed like the kind of engine that would be described as "bottom end only". Basically, I ran a 5 port on the hot side (280 degrees) and really did get the best of both worlds. Just my .02
I have a 7 port arriving tomorrow, I'll let you know how they compare if you're interested.
-Jake
InfiniteMotors is offline
Old 08-16-2009 | 08:16 PM
  #8301
Paperman 90's Avatar
Hey could u tell what pipe do u have on your 3 port race , have a ofna 086 on mine and i am only getting about 7 mins a tank in my buggy.
Thank You
Paperman 90 is offline
Old 08-16-2009 | 08:46 PM
  #8302
22Racer's Avatar
Originally Posted by BlueisBetter
hey 22racer
can you explain this better install a shim under the sleeve...!!!
you mean the piston sleeve this would raise the ports right but wouldnt that close of the exaust port
Grizz is right, I am shimming the sleeve up to change timing of the motor. (thin shim under the sleeve) It takes away a little bottom end and gives it more top end. I have been doing this on alot of the 5 ports I sell but you can do it to most motors. I have a .25 6 port that runs really well with a timing change and the turbo button. I don't recommend someone that isn't good with engines to do it himself, the head shimming needs to be changed also. A modder once told me you can dremel all you want and it won't make as much of a difference as a timing change. I am finding this to be true.
Rex
22Racer is offline
Old 08-16-2009 | 11:44 PM
  #8303
grizz1's Avatar
Thanks Rex. Sounds like a good move. I assume you would need to reduce the head shimming by the same amount you place under the sleeve.
A thin shim being around .1 - .2 mm ?
Cheers
grizz1 is offline
Old 08-16-2009 | 11:47 PM
  #8304
grizz1's Avatar
-Jake
You thought the 5 Port had good top end - wait until you unleash the 7 Port It's like Dolly Parton - top heavy , but it has plenty of bottom too (sorry Dolly). Ideal buggy motor with 1.1 springs. You will love it.
280 is pretty warm. You will get plenty out of the GO's without wringing them that much
grizz1 is offline
Old 08-17-2009 | 12:20 AM
  #8305
MassiveMods's Avatar
Originally Posted by 22Racer
Russell did order a few Mg66's for some guy's that wanted to test them. He will order a bunch next time probably, this order was all Gx series motors.
Rex
Yes Rex he said you wanted to test them ...
MassiveMods is offline
Old 08-17-2009 | 12:28 AM
  #8306
LOL !!!
Old 08-17-2009 | 01:11 AM
  #8307
OzzyNitroJunky's Avatar
So from what I gather the more ports the more ""īnsane"" it gets?
OzzyNitroJunky is offline
Old 08-17-2009 | 01:35 AM
  #8308
grizz1's Avatar
Not really. Generally the more ports the more top end, and the fewer ports the more bottom end, but it's not always quite this direct a comparison in reality.
Of the GO models (stock motors) I think I would be safe in saying that the 5 Port has the best power of all, particularly bottom end power. Perhaps because it's a happy medium between the 3 and 7 port models, it has the best of both worlds ? Massive or someone else in the know would be able to explain it all better (when he gets a spare moment away from the 66 orders )
grizz1 is offline
Old 08-17-2009 | 07:19 AM
  #8309
Default awsome
sweet
Old 08-17-2009 | 07:32 AM
  #8310
bigmatt's Avatar
Rex
Is this the break in shim that massive mods sells? That fits under the cylinder to crank case. or are you using a.01mm shim,drilling the notch?
bigmatt is offline
