Go-Tech Engines Thread
#1233
Exactly. It's more responsive too. I bought my 5-port as a standard head button and ran it like that for a few gallons before switching to the turbo. It was a noticeable improvement.
#1236
Guys i need help on the 5 port.
It seems that the modified i intended to buy is almost double the price of the stock one. Shall i go for it or not?
I think that my LHS has only the 5 port in standard plug and sells the turbo button separately...will i notice any significant performance boost over the standard plug if i install a turbo?
How about runtimes?
And one last question...i will be using a JP-1 exhaust with the 5 port is this OK as far as runtime concern? I suppose that the low end power will be more than enough.
How about runtimes?
+1 on the turbo, it offers a greater feel from top to bottom, and just knowing the purpose of a turbo head is a ease of the mind for me, nice smooth chamber
#1238
i got ? for everyone i got some carb orings loose they vibrate when running and are easy to turn awaiting parts to replace orings can you put sealer on the threads and help keep the needle from turning thnx will g
#1245
Where are you racing? indoor outdoor, i race indoor for the winter and run a P6=hot and when outdoor i go with a P3= ultra hot, with a cooler plug your tunning window decreases, a hot or ultra hot broadens this effect, and for outdoor with temps and air changing the way it does the hotter plug is great, but for cool clean air like indoor or just a nice day outdoor you can try a hot, med plugs don't seem to idle as well also, the heat of the plug should be chosen by the air your runnning in. But for the GO 5 port turbo a P6 or P3 will work great, thats all i run and have great succsess.
2Likes
