Go-Tech Engines Thread
#691
will g the turbo button will increase both your run time and power across the rpm band, and maybe a change to the 086 pipe might help to tame down the bottom and make the car more drivable getting even more run time...
#693
hey guys i think i am going to get the 5 port turbo if i can afford it but not sure if i can. i have to get it from amain. What turbo plug should i get they no longer carry the OS brands and O'donnel brands?
http://forums.amainhobbies.com/index...pic,272.0.html
#694
this is the plugs im using in my Go turbo engines http://www.amainhobbies.com/product_...oducts_id/2350...
hope this helps...if you cant afford a 21-5T maybe you may look into a 21-3 and order a turbo button for it, this would be a killer engine for a killer price...
#695
I finally got the 053 and 086 for my 5P turbo. I was going to test it at nitro pit but it got rained out this weekend
But I did able to run a comparison at some undeveloped home lots by my house. I started with the 053 and once I got it warmed up, I started to tune it in. The jammin broke loose on awesome damp clay. I can see it will have no problem making jumps coming off corners but it ran out of steam on long straights. Not going to be the pipe for the Pit. I also timed it. It ran out of fuel in 8 minutes. The temp was 210 and ended at 236 on empty.
I changed to the 086 same settings and the thing would bog down low. I continued to lean her out until she was able to get off without hesitation. BTW, this was 6 hours leaner on the needle. I topped it off with fuel and started to drive it. Good bottom as I able to still break loose the tires (new PL step ups). Great top end. It ran for 11 minutes, unbelievable! The temp was 205 and ended at 235.
I can't wait for the next race to see how it fairs with the other engines. Keep you posted.
Tom
.But I did able to run a comparison at some undeveloped home lots by my house. I started with the 053 and once I got it warmed up, I started to tune it in. The jammin broke loose on awesome damp clay. I can see it will have no problem making jumps coming off corners but it ran out of steam on long straights. Not going to be the pipe for the Pit. I also timed it. It ran out of fuel in 8 minutes. The temp was 210 and ended at 236 on empty.
Tom
#698
Hey All
Had a lot of people asking about our site , its up and running now
thanks for your patience
NB all international Go Engine mod engines back on line only a 2 week waiting list now
cheers MM
www.massivemods.com.au
cheers MM
#699
, pm me back if you have anymore questions on it.
#700
#703
Hey Massive, New web site looks great. Nice graphics and very user friendly.
Now that my new 5 port is broken in I´m thinking about a turbo head button. From what I have read here there is a definite performance increase from standard plug - yes ?
2Likes
