Sirio engines thread
#2162
#2164
is there anyone familier with the sirio EVO4 tuning setup? i've tried mine and it seemed the power is not as satifying as the EVO3 STI. Any advice on the clutch tuning for this EVO4. I've tried the same clutch setup as the EVO3STI but the engine became lag, then i tried to increase the clutch engagement (tighten more) and it increased a little but runtime was effected. I've even tried various clutch gap but still the same. Can anyone suggest me the needle setting or power setting for his engine.
TQVM
TQVM
#2167
#2168
#2169
have u tested the engine? how the clutch setup? is it similiar to the Evo3STI? how the power? I hope it is the same because it uses the STI conrods, crankshaft, and the design of the piston and sleeve looked similiar to the Evo3STI
#2171
#2172
as for the clutch it is way lighter than the standard RRR system & will be getting it ready for my next race so I will be able to give you more info but the clutch is really sweet
#2174
Never experienced this before. Are u using the correct sirio plugs? or have the threads on the plugs or at the turbo head been compromised? probably u screwed it (plug) in to fast without matching the thread correctly, and damaged the thread on the turbo heads?
1Likes
