Sirio engines thread
#2176
Evo 4 Piston & sleeve looks identical to the 3 I have not inspected the crankshaft yet & have not had a chance to break it in as for the power I've seen Toso running it for a couple of races & there's no doubt that it is fast
as for the clutch it is way lighter than the standard RRR system & will be getting it ready for my next race so I will be able to give you more info but the clutch is really sweet
#2177
The engine was running just fine up until 2 races ago. The race prior to that, I burned a plug because of a blown exhaust gasket - and it was the last race of the day, so it didn't really matter. So 2 races ago, no matter what I tried, I couldn't get the idle to come down right away after being on throttle. While looking straight down at the engine, I noticed some fuel "percolating" around the base of the glow plug. I wiped it, put the plug back in and the same thing happend.
I know I have to replace the button head - just wondering if anyone had similar problems. I've never had problems like this with my other engines and IMO, the glow plug doesn't thread in as cleanly.
Just fyi - I am using this type of glow plug wrench:
#2178
#2179
the clutch system can be obtained from the-border it's not cheap either since you have the euro exchange but hopefully we can get them in the states soon
#2180
Good choice on plug driver Rmd, i found the same T-handle over here!
#2181
Yes, I am using Sirio turbo glow plugs.
Very possible. When I first got the engine, I stripped the threads the first time I put in a glow plug and had to replace the button head before even starting up the engine. Ugh! That was over a year ago.
#2186
The Evo 4 has just arrived @ Kyosho America just have your LHS place the order they are also looking into getting the New Sirio clutch system as well
#2189
#2190
1Likes
