Like Tree1Likes
Sirio engines thread
Old 10-29-2007 | 06:50 PM
  #2146
doc56's Avatar
Originally Posted by Scott Fisher
Look at the picture 4 posts up
which factory produces this clutch assembly?
doc56 is offline
Old 10-29-2007 | 07:01 PM
  #2147
rmdhawaii's Avatar
Sirio... http://www.redrc.net/2007/05/sirio-p...h-for-nt1-rrr/
rmdhawaii is offline
Old 10-29-2007 | 07:25 PM
  #2148
GMartinez's Avatar
Originally Posted by stefan
.12 STI Evo4:
Quote: "Now available, known as the EVO4, the latest generation of World Champion 12
size IC Sirio engine has been launched! The Sirio 12 Evo4 features a 3 ports
ABC Efra legal liner assy, a special STI type black crankshaft, also
complying to the 2007/2008 Efra rules. Using some new material on the
carburettor main needle, a new conrod, a new lightweight efficient cooling
head, the Evo4 will offer the highest performance from a 1:10 IC 200mm
Touring car, when coupled with the dedicated tuned-pipe line and the Kyosho
2D clutch set. Some new Ceramic rear bearings are available as option."
Also the clutch disk is in aluminum
GMartinez is offline
  #2149
GMartinez's Avatar
.12 STI Evo4:
Also the clutch disk is aluminum
Old 10-29-2007 | 07:33 PM
  #2150
Team Kamikaze's Avatar
It looks exactly a copy of the Serpent 720 clutch system, except for the clutch shoe being blue.
Team Kamikaze is offline
Old 10-29-2007 | 07:52 PM
  #2151
GMartinez's Avatar
The clutch bell has been around for a while & it does not look like the serpent the flyweights is nothing new that type has been around for years with other manaufacturers so post a pic of the serpent system so everyone can compare that have similiarity's but are not an exact copy
Old 10-29-2007 | 08:00 PM
  #2152
The bottom line is Serpent invented the CENTAX and yes the flyweights have been around for years because Serpent have been using it.
Old 10-29-2007 | 08:05 PM
  #2153
GMartinez's Avatar
Bottom line is the bell is not an exact copy & no need to get so defensive I ran the impulse,710, tested the 720 as well so I do know the product as well
Old 10-29-2007 | 08:54 PM
  #2154
Okay except the clutch BELL happy now?
By the way it is also an exact copy of the MUGEN HO780 Clutch system, EXCEPT for the BELL.
Old 10-29-2007 | 09:54 PM
  #2155
Mugenville's Avatar
Is there an alternate plug you can use other than the Sirio #7 plug in my EVO3, seems there a bit hard to get at the moment
Mugenville is offline
Old 10-29-2007 | 10:02 PM
  #2156
GMartinez's Avatar
you said exactly
Old 10-29-2007 | 10:05 PM
  #2157
GMartinez's Avatar
IDM plugs are equal I have used in the past O.S. & Novarossi to get by
Old 10-29-2007 | 10:15 PM
  #2158
Robert,
I got SIRIO S7 turbo plugs in stock!
Old 10-30-2007 | 01:13 AM
  #2159
Mugenville's Avatar
thought the S7 was a buggy plug, but if they work i can get them here
Old 10-30-2007 | 01:59 AM
  #2160
M7H's Avatar
M7H
If they had only Patented there CENtrifugal To AXial clutch.....
M7H is offline
